Aeromotive Solves 5th Gen Camaro Woes with Another Stealth System
Its here! 5th Gen Camaro in-tank Stealth Fuel Systems. Hot Rod Magazine listed the fuel system on these modern muscle cars as one of the ?top 10 weak points.? In fact, it’s recommended that you upgrade your fuel system at 550 hp. Before the Aeromotive Stealth System, your only options were voltage boosters and finally, expensive twin-pump systems. What happens if one pump goes out? You won’t know until it’s too late.
Aeromotive has your solution. Similar to the successful Corvette Stealth System, the new Camaro System is a complete drop-in, single fuel pump assembly for 2010 and later Camaros. The system provides a single A1000 or Eliminator Fuel Pump capable of supporting big HP. The best part, it drops right into your factory tank. It still incorporates the factory jet siphon system, includes an integral 100-micron pre-pump filter and an ORB-08 return line port. Now you can plumb a true return-style system into your Camaro to support the power your making without the worry of the siphon system and while maintaining your factory fuel tank. All while saving you money!
PRODUCT FEATURES:
? Fits 2010 (5th gen) and later Camaros
? ORB-08 outlet and return port
? Incorporates factory jet siphon system and sending unit
? Includes an integrated 100-Micron Stainless Steel pre-pump filter
? Utilizes the factory tank, o-ring, lock ring and mounting location
? Includes everything necessary to install the pump into your tank.
? Remaining system plumbing not included. Stage 1, 2 and 3 Systems COMING SOON!
18673 – A1000 Camaro Stealth Kit 18674 – Eliminator Camaro Stealth Kit
(MSRP = $799.00) (MSRP = $979.00)
? Supports up to 1300 HP ? naturally aspirated ? Supports up to 1900 HP ? naturally aspirated
? Supports up to 1000 HP ? forced air induction ? Supports up to 1400 HP ? forced air induction
Aeromotive Inc. is a true high performance aftermarket manufacturer specializing in fuel delivery and fuel delivery components. Utilizing aerospace tolerances and procedures, 3 generations of track experience and a meticulous approach to engineering, Aeromotive Fuel Systems have become the absolute pinnacle of performance fuel delivery.
For more information on the Camaro Stealth Fuel System, Aeromotive or their extensive line of components and the advantages they can provide, go to www.aeromotiveinc.com. To speak with one of the highly qualified technicians, call (913) 647-7300.
