C2 Specs
Specs
Engine data is for 1967 L89
Standard Engine |
5.7L V8 |
Standard Transmission |
3 Speed Manual (1968-69) |
Cylinders |
8 |
Number of Valves |
16 |
Horsepower @RPM |
200 hp@ 4200rpm |
Torque @RPM |
283 lb.ft@ 2800rpm |
Fuel Economy Cty/Hwy |
N/A |
Combined Fuel Economy |
21 |
EPA Class |
Two Seater |
Fuel Type System |
Gas Engine / Cross-Fire Throttle Body Fuel Injection |
Overdrive Transmission |
Yes |
Compression |
9.0:1 |
Displacement |
5733cc/350ci |
Bore X Stroke (in) |
4.00×3.48 |
Cruising Range |
420 miles |
Power to Weight Ratio |
11 lb/hp |
Valves Configuration |
Overhead Valve |
Supercharged |
No |
Brakes, Steering, Suspension and Tires.
Brakes (Front) |
Disc |
Brakes (Rear) |
Disc |
Driveline |
Rear Wheel Drive |
Steering |
Rack & Pinion |
Steering Diameter |
40.0 ft. |
Suspension (Front) |
Independent |
Suspension (Rear) |
Independent |
Tire Type |
Passenger |
Tire Size Front |
7.75 x 15 |
Tire Size Rear |
7.75 x 15 |
Tire Construction |
Bias-ply |
Interior Dimensions.
Seating |
2 |
Headroom |
37.0 |
Shoulder Room |
53.9 |
Hiproom |
49.3 |
Legroom |
42.0 |
Exterior Dimensions and Weight.
Curb Weight |
3360 |
Height |
49.8 |
Length |
175.1 |
Top Type (Standard) |
Hard Removable, Partial (Includes lift-out panels, T-Roofs and Targa Tops. Targa Tops can be removed but the rear window is left in place) |
Top Type (Optional) |
HP |
Track (Front) |
56.3 |
Track (Rear) |
57.0 |
Wheelbase |
98.0 |
Width |
69.6 |
Doors |
2 |
Performance.
1/4 mile |
16.1 sec @ 84.5 mph |
0-60mph |
7.9 sec |
skidpad |
0.82g |
slalom |
62.6 mph |
coefficient of drag |
0.44 |
Related
