C3 Specs
Specs
Engine data is for 1982 L83
Standard Engine |
5.7L V8 |
Standard Transmission |
Automatic only (1982), 4 Speed Manual (1970-1981), 3 Speed Manual (1968-69) |
Cylinders |
8 |
Number of Valves |
16 |
Horsepower @RPM |
200 hp@ 4200rpm |
Torque @RPM |
283 lb.ft@ 2800rpm |
Fuel Economy Cty/Hwy |
N/A |
Combined Fuel Economy |
21 |
EPA Class |
Two Seater |
Fuel Type System |
Gas Engine / Cross-Fire Throttle Body Fuel Injection |
Overdrive Transmission |
Yes |
Compression |
9.0:1 |
Displacement |
5733cc/350ci |
Bore X Stroke (in) |
4.00×3.48 |
Cruising Range |
420 miles |
Power to Weight Ratio |
11 lb/hp |
Valves Configuration |
Overhead Valve |
Supercharged |
No |
Capacity and Volume.
Cargo Volume (EPA) |
12 cu. ft. |
Cargo Volume (MFR) |
12.6 cu. ft. |
Fuel Capacity |
20.0 gal |
Passenger Volume (EPA) |
48 |
Passenger Volume (MFR) |
48.7 cu. ft. |
Brakes, Steering, Suspension and Tires.
Brakes (Front) |
Disc |
Brakes (Rear) |
Disc |
Driveline |
Rear Wheel Drive |
Steering |
Rack & Pinion |
Steering Diameter |
40.0 ft. |
Suspension (Front) |
Independent |
Suspension (Rear) |
Independent |
Tire Type |
Passenger |
Tire Size Front |
225/60-15 |
Tire Size Rear |
225/60-15 |
Tire Construction |
Radial |
Interior Dimensions.
Seating |
2 |
Headroom |
37.0 |
Shoulder Room |
53.9 |
Hiproom |
49.3 |
Legroom |
42.0 |
Exterior Dimensions and Weight.
Curb Weight MT |
3425 |
Curb Weight AT |
N/A |
Height |
47.8 (MY 1968) 48.0 (MY 1982) |
Length |
182.1 (MY 1968) 185.3 (MY 1982) |
Top Type (Standard) |
Hard Removable, Partial (Includes lift-out panels, T-Roofs and Targa Tops. Targa Tops can be removed but the rear window is left in place) |
Top Type (Optional) |
HP |
Track (Front) |
58.7 |
Track (Rear) |
59.5 |
Wheelbase |
98.0 |
Width |
69.2 (MY 1968) 69.0 (MY 1982) |
Doors |
2 |
Performance.
1/4 mile |
16.1 sec @ 84.5 mph |
0-60mph |
7.9 sec |
skidpad |
0.82g |
slalom |
62.6 mph |
coefficient of drag |
0.44 |
Related
