C4 Specs
Specs
Engine data is for 1996 LT1
Standard Engine |
5.7L V8 |
Standard Transmission |
6 Speed Manual |
Cylinders |
8 |
Number of Valves |
16 |
Horsepower @RPM |
300 hp@ 5000rpm |
Torque @RPM |
335 lb.ft@ 3600rpm |
Fuel Economy Cty/Hwy |
15/23 mpg |
Combined Fuel Economy |
N/A |
EPA Class |
Two Seater |
Fuel Type System |
Gas Engine / Sequential Electronic Fuel Injected |
Overdrive Transmission |
Yes |
Compression |
10.4:1 |
Displacement |
5733cc/350ci |
Bore X Stroke (in) |
4.00×3.48 |
Cruising Range |
460 miles |
Power to Weight Ratio |
11 lb/hp |
Valves Configuration |
Overhead Valve |
Supercharged |
No |
Capacity and Volume.
Cargo Volume (EPA) |
12 cu. ft. |
Cargo Volume (MFR) |
12.6 cu. ft. |
Fuel Capacity |
20.0 gal |
Passenger Volume (EPA) |
48 |
Passenger Volume (MFR) |
48.7 cu. ft. |
Brakes, Steering, Suspension and Tires.
Brakes (Front) |
Disc |
Brakes (Rear) |
Disc |
Driveline |
Rear Wheel Drive |
Steering |
Rack & Pinion |
Steering Diameter |
40.0 ft. |
Suspension (Front) |
Independent |
Suspension (Rear) |
Independent |
Tire Type |
Passenger |
Tire Size Front |
255/45-17 |
Tire Size Rear |
285/40-17 |
Tire Construction |
Radial |
Interior Dimensions.
Seating |
2 |
Headroom |
37.0 |
Shoulder Room |
53.9 |
Hiproom |
49.3 |
Legroom |
42.0 |
Exterior Dimensions and Weight.
Curb Weight MT |
3298 |
Curb Weight AT |
N/A |
Height |
47.3 |
Length |
178.5 |
Top Type (Standard) |
Hard Removable, Partial (Includes lift-out panels, T-Roofs and Targa Tops. Targa Tops can be removed but the rear window is left in place) |
Top Type (Optional) |
HP |
Track (Front) |
57.7 |
Track (Rear) |
59 |
Wheelbase |
96.2 |
Width |
73.1 |
Doors |
2 |
Performance.
1/4 mile |
13.7 sec @ 105.1 mph |
0-60mph |
5.2 sec |
skidpad |
0.88g |
slalom |
62.6 mph |
coefficient of drag |
0.29 |
Related
