C5 Specs
By -
c5-620x180a
Specs
  • Engine data is for 2001-2004 LS1
    Standard Engine 5.7L V8
    Standard Transmission 6 Speed Manual
    Cylinders 8
    Number of Valves 16
    Horsepower @RPM 350 hp@ 5200rpm
    Torque @RPM 375 lb.ft@ 44000rpm (manual, 360 lb.ft in automatic)
    Fuel Economy Cty/Hwy 19/28 mpg
    Combined Fuel Economy 23
    EPA Class Two Seater
    Fuel Type System Gas Engine / Sequential Electronic Fuel Injected
    Overdrive Transmission Yes
    Compression 10.1:1
    Displacement 5665cc/346ci
    Bore X Stroke (in) 3.90×3.62
    Cruising Range 414 miles
    Power to Weight Ratio 9.27 lb/hp
    Valves Configuration Overhead Valve
    Supercharged No
  • Capacity and Volume.
    Cargo Volume (EPA) 24 cu. ft.
    Cargo Volume (MFR) 24.8 cu. ft.
    Fuel Capacity 18.0 gal
    Passenger Volume (EPA) 51
    Passenger Volume (MFR) 51.4 cu. ft.
  • Brakes, Steering, Suspension and Tires.
    Brakes (Front) Disc
    Brakes (Rear) Disc
    Driveline Rear Wheel Drive
    Steering Rack & Pinion
    Steering Diameter 40.2 ft.
    Suspension (Front) Independent
    Suspension (Rear) Independent
    Tire Type Passenger
    Tire Size Front 245/45-17
    Tire Size Rear 275/40-18
    Tire Construction Radial
  • Interior Dimensions.
    Seating 2
    Headroom 37.9
    Shoulder Room 55.3
    Hiproom 54.2
    Legroom 42.7
  • Exterior Dimensions and Weight.
    Curb Weight MT 3246
    Curb Weight AT N/A
    Height 47.7
    Length 179.7
    Top Type (Standard) Hard Removable, Partial (Includes lift-out panels, T-Roofs and Targa Tops. Targa Tops can be removed but the rear window is left in place)
    Top Type (Optional) HP
    Track (Front) 61.9
    Track (Rear) 62
    Wheelbase 104.5
    Width 73.6
    Doors 2
  • Performance.
    1/4 mile 13.25 sec @ 109mph
    0-60mph 4.8 sec
    skidpad 0.92g
    slalom 61 mph
    coefficient of drag 0.29
