C6 Specs
Specs
Engine.
Standard Engine |
6.2L V8 |
Standard Transmission |
6 Speed Manual |
Cylinders |
8 |
Number of Valves |
16 |
Horsepower @RPM |
430 hp@ 5900rpm |
Torque @RPM |
424 lb.ft@ 4600rpm |
Fuel Economy Cty/Hwy |
16/26 |
Combined Fuel Economy |
19 |
EPA Class |
Two Seater |
Fuel Type System |
Gas Engine / Sequential Electronic Fuel Injected |
Overdrive Transmission |
Yes |
Compression |
10.7:1 |
Displacement |
6162cc/376ci |
Bore X Stroke (in) |
4.07×3.62 |
Cruising Range |
342 miles |
Power to Weight Ratio |
7.5 lb/hp |
Valves Configuration |
Overhead Valve |
Supercharged |
No |
Capacity and Volume.
Cargo Volume (EPA) |
22 cu. ft. |
Cargo Volume (MFR) |
22 cu. ft. |
Fuel Capacity |
18.0 gal |
Passenger Volume (EPA) |
52 |
Passenger Volume (MFR) |
52.1 cu. ft. |
Brakes, Steering, Suspension and Tires.
Brakes (Front) |
Disc |
Brakes (Rear) |
Disc |
Driveline |
Rear Wheel Drive |
Steering |
Rack & Pinion |
Steering Diameter |
39.0 ft. |
Suspension (Front) |
Independent |
Suspension (Rear) |
Independent |
Tire Type |
Passenger |
Tire Size Front |
245/40-18 |
Tire Size Rear |
285/35-19 |
Tire Construction |
Radial |
Interior Dimensions.
Seating |
2 |
Headroom |
37.7 |
Shoulder Room |
55.2 |
Hiproom |
53.7 |
Legroom |
43.1 |
Exterior Dimensions and Weight.
Curb Weight MT |
3208 |
Curb Weight AT |
N/A |
Height |
49.1 |
Length |
174.6 |
Top Type (Standard) |
Hard Removable, Partial (Includes lift-out panels, T-Roofs and Targa Tops. Targa Tops can be removed but the rear window is left in place) |
Top Type (Optional) |
HP |
Track (Front) |
62.1 |
Track (Rear) |
60.7 |
Wheelbase |
105.7 |
Width |
72.6 |
Doors |
2 |
Performance.
1/4 mile |
12.15 sec @ 118.6mph |
0-60mph |
4.1 sec |
skidpad |
0.97g |
slalom |
63.4 mph |
coefficient of drag |
0.31 |
Related
