How-To Tuesday: Corvette Clunk Noises
By -
c5 Z lift
I have personally run in to this issue. As a matter of fact, it drove me crazy for several months. I could go on and on about different reasons why it drove me crazy, but in the end I was finally able to track down the noise coming from the suspension of my Corvette. I sincerely hope it doesn’t take you as long as it did me.
So how was I able to track down the clunking sound emanating from the back of my Corvette? Well, unfortunately for me, I just had to buck up and take it to a mechanic. But perhaps if I had Corvette Forum back then (I won’t say how long ago that was), maybe I could have tracked down the source of the noise and solved the problem on my own. You all are lucky; if you are facing this issue, you now have a solutionĀ in today’s How-To Tuesday article.
The article goes through several different issues that you could be facing if you have a mysterious rattle or clunking sound. One of the easier items listed on the article is checking the sway bar end links. The fix on this particular issue is quite easy. I would imagine that for those of you who drive with “more spirit,” this could be one you may come across.
Fortunately, you don’t have to do a frame-off restoration to work through any of the issues mentioned in the article. However, you would likely find your issue if you did. Either way, good luck with the problem solving. I hope you find your elusive sound sooner than I did!
Read the entire Corvette Forum How-To article. >>
