Introducing the QTP Electric Exhaust Cutout
Unleash The Power!
No need to crawl under your car or truck ever again to uncork your exhaust. No need to run a loud muffler all the time to get the maximum horsepower for your ride. With the Quick Time Electric Cutout(QTEC) you can have the best of both worlds.
Quiet For The Street, Riot For The Strip!!
Go from stealth
quiet to wide open power and experience the gains even if you are
already enjoying an aftermarket exhaust system. You control the volume,
you control the power. Open your exhaust with the flip of a switch. Run
it closed, run it all the way open or any position in between. Adjust
your back pressure to save gas.
Does not matter whether you call
it an electric exhaust cutout, exhaust dump or e-cutout, you know your
getting the ultimate exhaust upgrade for your car or truck.
More Size Options than any other Cutout on the Market!
Kits
are available for any application from old school muscle to high tech
imports. Sizes range from 2.25″, 2.5″, 3″, 3.5″ and 4″ and our popular
Low-Profile Oval Cutout kits. If your tight on space? No problem the Low
Profile kits are totally customizable as they do not require the
standard round Y-pipes. Instead QTP will ship you their polished
connection tubes in the kit; from there you cut the pipe to the length
and angle that’s just right for YOUR specific vehicle. Have questions as
to which one will work best for your vehicle? Call (201) 444-0998!
They’ll be happy to help.
The Best just got even Better!
NEW
for 2011! QTP has taken the proven QTEC to the next level. After 2
years in R&D, QTP is proud to offer their electric exhaust cutouts
with a new cast aluminum motor cover. Starting with a CAD file, they
designed a cover for the electric motor. Casted with 360 grade aluminum,
then CNC machined on the interior for a precision fit. But they didn’t
stop there; they took it one step further, using a powder coated
finishing process to protect it and keep your electric cutouts looking
better than ever! Whether your application is Street or Strip, a Hot Rod
or the Family SUV, the Motor Cover provides your ride with Full Metal
Jacket Protection. Another Industry First!
FEATURES:
-CNC 6061 Aircraft Aluminum Body
-Full Metal Motor Cover/ Powder Coated Satin Finish
-Stainless Steel Butterfly Plate
-Stainless Steel Shaft
-6061 Aircraft Aluminum Motor Plate
-High Torque DC Gear Driven Motor
-Gears Made from High Temp Steel for Long Life
-2 position Momentary Toggle Switch
-Weather proof wiring harnesses
-Weather tight Connectors for Superior Sealing
-Proudly made in the USA
For more information, check out http://www.quicktimeperformance.com/QTEC/index.php/
