Keyless Entry Remote Maintenance
By -
If your remote
seems intermittent or requires a shake to work, try cleaning the motion
Open the remote case. The switch is the gold tit thing between
the buttons. There is a small ball in there so don’t lose it when you
take the cover off. Remove the whole circuit board from the case and turn
it over. Push the 2 gold tabs to pop off the cover. Clean with alcohol and
reassemble. The ball is gold plated too(mine was grey with dirt).
Comments ()
