Possible Remedy for Stuck Window
By -
It seems to
be quite a common problem for the passenger window motor to stop working.
The problem seems to stem from the fact that the window does not get used
very often. Try to use the windows at least once a week to keep the motors
in good working order.
My \’99 widow stuck recently and the best
tip I received was to hold the door window button just as you close the
door (fairly firmly). The tip worked perfectly.
Comments ()
