Resetting Tire Pressure Monitors
By -
I used this
message forwarded from a fellow forum memeber and it worked just as
described. Thought I would post for anyone else that may need to reset
their TPMs.
1) Turn ignition on
2) Press \”Reset\” button in
order to clear any IPC display warning messages
3) Press and release
the \”Options\” button on the DIC to scroll through the
display
options until the IPC display is blank
4) Press and hold the DIC
\”Reset\” button for 3 seconds
5) Press the \”Options\” button
again until TIRE TRAINING message appears
6) Press \”Reset\” button
until the IPC \”Learn L Front Tire\” message appears in
order to
begin the programming
7) Install the J41760 Tire Pressure Monitor
(TPM) System Programming Tool
(large magnet will do) over the left
front valve stem
8) The horn will sound, indicating the left front TPM
sensor is programmed
(if this takes more than 15 seconds, pull magnet
back and try again, it will
give you three tries. Then you must start
over)
9) When the horn sounds, proceed to program the next TPM sensor
in the
following order as directed by the IPC messages:
-Learn R
Front Tire
-Learn R Rear Tire
-Learn L Rear Tire
Programming can be canceled by turning ignition off, waiting 2
minutes with
no sensors being learned, finishing all 4 wheels or
through the DIC.
If the programming is canceled with less than 4
sensors learned, it will only
accept the codes programmed up to that
point.
