[ANSWERED] C6 Z06 Question for Tadge Juechter
#181
As for people wanting a long term fix, what exactly are you expecting? 100k with no head maintance? Valve guides wear on all motors, so what is acceptable to vette people? If they come out and say "because of the high performance high revving nature of the ls7, additional maintenance up to and including replacing guides every 15-30k miles is recommended", what is wrong with that?
#182
Replacing guides/etc if you do it yourself is ~800-900s. Lots of cars have timing belt changes every 60k that cost at least that. Part of owning a high performance car is higher maintenance. Maybe GM built a car that the owners weren't ready for.
Only motors that have valve guides that don't need replaced are Teslas and rotarys. Every other motor will need them serviced at one point or another.
For me, if it is replace them every 30k, that is fine. That is 4-5 years of use, and a weekend and $1000 every 4-5 years it completely acceptable to me for a high performance car. Hell my motorcycle needs valves adjusted and major service every 15k that is about the same cost but it isn't strange and people don't complain to Ducati to fix the valve issue, that is just normal on motorcycles.
#183
Such critical inspection / replacement intervals should be clearly stated in the maintenance schedule. Perhaps someone can post a link to the one for the C6Z and highlight the published interval for the valve guides. If it's 15k - 30k, then my bad for failing to consider this before purchasing the vehicle.
#184
Ha - are you trolling us, Unreal? This must be a joke... cause it sure sound ridiculous to think internal motor components need to be replaced like spark plugs and timing belts. Well, unless you think that's the best engineering that GM can offer these days. I'm pretty sure Tadge would expect no less than at least 125k-150k+ good miles out of these LS7's. Otherwise, I'd be quite embarrassed to be on that team that engineered this motor.
Maybe we should all just wait until Tadge or someone else from GM has additional input. Otherwise we're just rehashing all the same things that were stated in the other million threads...
caffeine (05-20-2017)
#185
IMO, I feel normal wear for a engine like the LS7 under street use, well maintained with no track use should be about 150Kmiles. It would be reasonable to me if the engine is raced a lot, service mileage would decrease accordingly. GM usually boggy'd their vehicles for 100K miles during the 1980s, I remember reading some time ago.
#186
Received 1,335 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
Some really nutty replys here, actually unbelievable. Replacing heads more often than spark plugs, yeah that's normal. Much easier to change the plugs with the heads off LOL.
#187
Agreed, but all OEM automakers have been JIT for a long time now. That may not be common knowledge, but that is how manufacturing works in the modern world.
Maybe we as the consumers have too high of expectations for a high RPM 500hp push rod motor? I can see being pissed not knowing about it before hand, but to me, just inspect, repair, and replace every 20k+ miles and enjoy the damn car. It has enough other issues to address when the heads are an easy fix.
Secondly, if they are giving me a 5/100K powertrain warranty...then, yes; 100K is the absolute minimum I would accept before any valvetrain maintenace were needed.
#188
Agreed, just playing devils advocate. People say they want a fix, well what is a fix? If the fix is what I'm talking about (sadly 1/2 joking but that maybe as good as it ever gets) then are people just going to sell them and move on?
I think no internal motor work through warranty is what should be acceptable, so 100% agree on the 5 year 100k part.
Not trolling, just trying to have a decent conversation.
So what about track then? Would it be unreasonable to have to refresh a ls7 every 30-50k miles if it sees track 5-10 times a year?
Maybe in the future, if this is what is expected, GM makes it very clear in the manual, and sales what people are getting. If a z06 or "race ready" track day car is going to be sold, and can't go 100k+ without just your normal oil changes/etc, then it should be presented as such.
#189
a couple of abused track LS6s lost valves... There was no widespread issue with the engine.. but it did happen... track duty is such a different thing than street duty.. track miles are 10x tougher than street miles if not more....
That being said... There is no design flaw. The LS7 is as good as it gets... and sadly after this debacle we will never have a similar engine from GM again... but had GM used the technology they are using now (robots and pictures) they would have gotten the issue before it got widespread.
#190
#191
No design flaw? So you have all the drawings? If so share them.
#192
GM is still using the same outside supplier (Linamar) that messed up the heads for the C6 Z06, and they managed to not do proper oil fill on the e-difs of several thousand new C7 Z06's, with resulting failures as the low fluid level was not discovered in many PDI's, including at the NCM. One CA buyer got to Texas before the e-dif ate itself.
#193
I understand track use is a major factor in wear; however, we know low mileage/mild use vehicles are wearing guides. That doesn't meet my personal expectations.
If guides need to be changed every 50K miles, then I expect to know up front about it so it can go into my decision making process prior to purchasing the vehicle.
As for a long term fix, the ability to identify/purchase/install a set of heads that will wear guides at a rate comparable to other GEN IV GM motors (LS2/LS3) under similar use is what I would consider a fix. I don't ever expect that to come from GM willingly, because it will increase their exposure to liability.
#194
Based on the recommended service schedule in the owners manual, 100k with no head maintenance.
If the OEM tires wore out within 100 miles, would you consider that acceptable?
Maybe we as the consumers have too high of expectations for GM.
#195
I 100% agree.
Tires are a good point though. They put $2000 tires that wear out in 5-6k miles on the car, yet because people know that up front you don't see people bitching about it. Having $1000-2000 in head work more often than other cars sucks, but could be just part of owning one of these cars.
I completely agree, heads should last 100k miles no questions asked. Everything on the car besides the consumables (tires, brake pads, rotors, fluids) should last the warranty period.
The 06s did have a 3 year 36k mile warranty, so if they kept that would that change things? Maybe it was designed around that goal.
#197
C7 Corvette
I have a 2014 left over Blade Silver Corvette [had 5 other silver Corvettes] that I had to buy out of state, pretty common with Corvette owners. This is by far the worst paint job I ever had on any car. GM blows everyone off, Bowling Green admitted to paint issue among other things, changed their procedures?? so said... yet do absolutely nothing for the customers who have them? One is getting a little results from filing with the BBB and another has just filed [which I will do now to] and he is still waiting results.
In the past it was GoodYear tires vibrations, no tire life, 427 dropping valves, orange peel, mottling among other paint issues... mottling not actually admitted but I [an many others] have a car to prove it. Now ZO6 issues with Michelin tires cracking. One thing on top of others and nothing being done for the poor quality control paint jobs for one, that these owners purchased some sight unseen, [mine for a good reason, disabled veteran can not travel long distances] and GM saying it meets factory specs... scary... after using another car with the same issues to judge it buy?
I alone have talked two people out of buying Corvettes, and two people on trucks not to buy a GM product. You guys are writing your own epitaph.. Wake up GM and Bowling Green... spend the money on your customers instead of a big bash at the Corvette Museum in 2015 and get back to apple pie and Chevrolet Corvette... the American way..
#198
I've have similar feelings particularly on the HEMI engines especially the Apache 6.4L engine. The Apache does only have a 6400 rpm redline though; however, GMs own LS3 and LS9 have 6600 rpm redlines. I personally don't understand how another 400-600 rpm of rev range would cause guides to wear 3x as fast, if it were only the high performance nature of the LS7 causing the guide wear.
#199
I 100% agree.
Similarly, I know very little of the Brodix and/or MAST heads for the LS7, do those companies produce their own head castings? The Brodix website seems to indicate that they do.
If Linamar is indeed the culprit here, would it follow that going to a completely different head manufacturer potentially produce results we are looking for? I'm sure that question has been asked multiple times before.
#200
Yes, PRC, All Pro, Brodix, Mast, Trickflow, etc all cast their own heads.
LS9s have shown to have guide wear issues too.
