Oil dip stick
Oil dip stick
I have built up the engine of my 1997 corvette tpi. It was put on a wrong flywheel, and after that I can not have oil dipstick in. Because it gets eaten up. That has happened several times. It looks like a s. What could be the problem.
Not enough info. Obviously more than a flywheel replacement was done, as the dipstick sits in pretty much the middle of the motor. What were the mods?
Looks like an S, but no actual burrs, just deformed? Are you forcing the dipstick in? Did you add headers?
More info needed...
More info needed...
More info needed...
More info needed...
I ran a few mil faulty flywheel. It turned out that the right flywheel should not be in balance. I drove with a wheel that was in balance. This with the result that there was a terrible vibration in the car. It was so bad that I could not see anything in the rearview mirror. The man who should repair this drove the car too hard on RPM, for my taste. Something I do not. it was after this incident
It was after this episode engine started eating dipstick. About 4 cm. We switched dipstick several times but the same thing happened.
Is there a possibility that something may have been crooked inside the engine
The dipstick is stuck so i have to use force to get it out. The first time we got it out in one piece, shape as an S. The second and Third time the dipstick broke. About 5 cm.
The engine is buidd on the original 370. To effect 400Hp
hard to get at what is being talked about here. The flywheel has nothing to do with the dipstick. There is nothing to do with 370 and a 97 vette either. not ci not hp, so this is a confusing situation.
Only thing that could hit it would maybe be a rod or crank. Possible that the stroke was changed and its causing interferance or something? I am fairly sure the exposed part of the dipstick is below the scraper so no idea how that would work, i guess part of the tube could be mauled in there as well.
What completely was done to the motor internally? And headers? Maybe the dipstick is in wrong now?
Oh i am sorry. Its a 1987 TPI. It was modified to 400 Hp
Op like Socko said you are in the wrong section I understand English doesn't seem to be your primary language but what you are typing is very confusing. before you post please go back and re read your post and re post so it makes more sense.. Alot of people will skip over it because it's difficult to read/ understand. Ill click on the report button the mods can get this in the correct section. This is for 1997-2004 Corvettes. Good luck
Nice post Chicago
Ok thank you
It sounds like the outside tube the dipstick goes into got bent or twisted. That might make the end of the dipstick turn the wrong direction and point too close to the crank and get hit by one of the rods or the crankshaft. The end of the dipstick only needs to go down the inside edge of the pan into the oil, not point to the center of the oil pan where it will get hit. Maybe the wrong flywheel balance vibrated it loose and turned it till it got hit.
It certainly seems like an issue with an incorrect oil dip stick and wrong tube for sure.
Where are you located? Is the oil pan stock? Do you have the original "FIRST" dip stick that was ruined? If it was a GM dip stick it would have an eight digit part number on it probably. What is that number?
Depending upon the car and a couple other pieces of information it could be wisest to maybe buy a used engine oil dip stick and the tube for the car from someone here on the forum.
You might want to maybe accumulate parts before dropping the oil pan so you could just do it once. If it's an issue with the tube, once you remove it, you'll be likely be unable to drive it until repaired.
I suppose they know the right parts. I will try to check the tube and buy one if it goes wrong again.
Thank you for answer
