85 vet starts for 5 seconds then dies
Put new fuel pump in new oil pressure switch and still dies shortly after you start it. The guy I got it from said he was doing about110 in it when it started losing power, pulled over and it died. Then he said it started right up and he went to push gas and it died. Also I noticed that when it starts the second I pushed the gas it dies.
Prolly get more specific advice over in the C4 Tech section. Just a thought.
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Not an expert on the C4 but it sounds like you are having an issue with the factory anti theft system (VATS). There is a relay on the passengers side, I believe it's behind the dash. I had an 84 with the same issue. Replaced or bypassed the relay, cant remember, and everything was fine. Good luck
Regards
Chip
Received 19,309 Likes
'20-'21-'22-'23-'24
