[Z06] 09 c6 zo6 hit the start button and nothing
sarceneaux
On my z06 when you hit the start button its nothing, then after a few seconds everything comes on but there is a ticking coming from in the fuse block under the hood,(#44 powertrain ign 1) so we changed it and it's still doing it? Help please i have checked all fuses relays and grounds and can not figure this out.
Received 4,551 Likes
2016 C2 of Year
2015 C3 of Year Finalist
What is the state of your battery?
I hope it just a loose or dirty connector, but it sounds like you need a new battery. Many have found that a discharged battery will often fail to take (or hold) a good charge. It happened to me once, and a new battery was the answer.
sarceneaux
new battery, new terminals just picked it up from D3 in Houston,tx while it was there they must of done something to cause this cause it didn't do that when we took it there, and at one point they told us they had to get a new key fob cause ower fob wasn't working but they never told us about starting issue which it must have had and they just thought it was key fob
Good luck with your fix!
I've had the computer get all pissy before when I was disconnecting the battery. disconnect the negative terminal and let it sit for a minute or so and see if that helps.
