C1 steering box remove from car
Old 01-18-2017, 10:34 PM
skeeter88
skeeter88's Avatar
Default C1 steering box remove from car
With everything disconnected how do you get the steering box and mask out of the engine compartment and does car need to be on a lift. Skeeter88
Old 01-19-2017, 09:18 AM
csherman
csherman's Avatar
Received 1,421 Likes on 734 Posts
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
what year ?
Early columns are taken out thru the grill opening.
skeeter88 (01-19-2017)
Old 01-19-2017, 09:20 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
on my 62 all I had to do is tip it up and pull it out
Bill
Old 01-19-2017, 09:24 AM
ohiovet
ohiovet's Avatar
2016 C1 of Year Finalist
Same as wmf62; disconnected everything column related, removed hood and gently removed up through hood opening.
No problems.
Old 01-19-2017, 09:30 AM
emccomas
Support Corvetteforum!
emccomas's Avatar
Received 1,283 Likes on 732 Posts
Year of car and column is important. 53-57 columns are longer than 58-62 columns.
I removed the original column from my 56 through the grill opening (with engine out) and replaced is with a column from a 60.
It was tight, and required a great deal of finesse.
The factory procedure was to drop the body on the chassis with the column already fed up into the dash.
Old 01-19-2017, 09:38 AM
jim lockwood
jim lockwood's Avatar
Received 6,507 Likes on 2,996 Posts
C2 of Year Finalist (track prepared) 2019
When I pulled the column out of my '60, I found it very helpful to also remove the LH exhaust manifold. I gained a LOT of working room.
Old 01-19-2017, 11:54 AM
csherman
csherman's Avatar
JV04 is right
the body drop was done with the column in place.
53-57 - the column is removed thru the grill opening - its not fun.
Old 01-19-2017, 12:25 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Removing the drivers seat will give you some breathing room so you don't have to worry about damaging the seat.
Doug
Old 01-19-2017, 01:21 PM
DZVette
DZVette's Avatar
Doug
If you are working on a '56 or '57, the attached PDF based on a procedure presented by Jan Johansen of Copenhagen might be of help.
Dave Z
Old 01-19-2017, 02:08 PM
GCD1962
GCD1962's Avatar
Bill
Be sure to remove the seat completely. Remove expansion tank and I've found it helps to disconnect the hood latch (hold up) so that you can swing the hood open a little more.
Didn't see it is for an earlier C-1. Mine, like Bill's is a '62
Old 01-19-2017, 06:23 PM
vettsplit 63
vettsplit 63's Avatar
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I am told that when you tilt it up, the gear box oil will run out of the tube. If you have the carpet in it, probably need to put a plastic bag over the end.
skeeter88 (01-20-2017)
Old 01-19-2017, 07:24 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
get a BIG bag, later columns have a bunch of holes...
Bill
To C1 steering box remove from car
Quick Reply: C1 steering box remove from car
