1996 Corvette Radio Bulbs Out
St. Jude Donor '13
Looks like I have two bulbs out in the radio unit. Has anyone replaced these bulbs. It requires un-soldering the old bulbs from the PCB board and re-soldering the new ones in.
Anyone do this? If so, does GM list the bulbs as seperate bulb service numbers? Any feedback is great.
Thanks,
Vic
Thanks,
Vic
I just did mine the other day, the directions are all you need. You do have to do some soldering.
https://www.corvetteforum.com/techti...=249&TopicID=2
I did mine last spring. The tech tip has all the needed info. I went ahead and replaced all the bulbs while I had it apart so I didn't have to do it all again soon. I took the time and cleaned the buttons on the AC/heater controls while I had everything apart.
