Can a 15" Sub FIT a c5? Kicker S15L7
Hey guys,
Simple question, can a 15 sub FIT a c5.
My car has nitrous and the bottle is in the middle storage compartment. I still have a alot of room right behind my seat area of the trunk (before the window). Can a 15" sub fit there?
Thinking about going with 1 S15L7 Kicker Solobaric and 1 Kicker KX1200.1 amp. Its 1200 at 1ohms so does that mean 1200 watts rms to 1 SUB?
This should be a sweet setup if I am thinking its 1200 watts RMS to 1 SUB.
If it fits, I am doing it. Let me know
-Zee
-Zee
Brandon has 2 15's in his car, so you should be able to fit one in ok.
http://www.geocities.com/slumpinc5/interior.html
That's pretty crazy, those two 15" square subs are acutally like 2 18" because there is 20% more airspace. What I heard is that you need a huge box to make these subs sound good. If you check out thirdgen.org (my source), and look up kicker L7 you'll probably find out more than you want to know. If you want to do it go for it would be pretty awsome, but if you want better SQ then my recommendation is to go elseware, you'll spend less money and better SQ in a small box with a round sub.
Oh and yes the 1200.1 is 1200 watts to one channel when wired to 1 ohm, which the sub can handle.
L7
I'm running a 10" L7 in a stealth box. (actually flush) 600 continuous 1200 max dual voice coil 2ohm. I run a Hifonincs Titan 1000 watt Class D 1ohm. Let just say it gets vicious when I turn it up. I run it turned down and the SQ is great turn it up and the 10" sounds like two 12's major SPL too. I think its a great middle of the road setup. I love it solobarics are nice subs. I can't imagine a 15" goodluck!
