Sponsored by: DashLynx
Pioneer Avic D-3 Install (lots of pics)
Old 02-07-2008, 05:33 AM
mojo1
mojo1's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15, '19
Mind telling me what camera you used, how good it is and how much ?
Old 02-10-2008, 03:56 PM
blaster903
blaster903's Avatar
awesome job on the install!!
Old 03-03-2008, 08:25 AM
Pro Street
Pro Street's Avatar
Where did you run your ipod wire and put your ipod?
Old 03-10-2008, 03:47 AM
Black$heep
Black$heep's Avatar
I ran the ipod cable through the center console. I popped out the cig lighter, drilled a small hole, and my ipod rests inside my center armrest
Old 03-10-2008, 08:07 AM
Pro Street
Pro Street's Avatar
I end up putting mine in the glove box because of the heat in the console.Thanks for the reply!
Old 03-10-2008, 08:59 AM
VET IT B
VET IT B's Avatar
Quick question? I have a 2000 vert with a 12 disc changer. Am installing a Z2 unit and removed the 12-disc changer.
There is a silver, about 6" X 6" box in the drivers side rear campartment with 2 plugs in it. Is this something with the changer or something else?
Thanks, Mark
Old 03-10-2008, 11:38 AM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
something else i belever, can u take a pic, are there any markings on it
Old 03-11-2008, 06:08 AM
VET IT B
VET IT B's Avatar
It's a silver metal box like PCM. It has one 24 pin and one 32 pin wiring harness going into it. Could it be something with my F45?
Old 03-22-2008, 07:03 AM
Sportsdude
Sportsdude's Avatar
Nice install
Old 03-01-2010, 04:49 PM
JMc
JMc's Avatar
Location: "This is not a psychotic episode, but a cleansing moment of clarity."
I had the Bose system and I tied into the stock 12 pin harness. The bose uses the speed sensor to raise and lower the volume according to the RPMs. The wire is at the back of the stock bose harness, dark green with a white stripe.
Ahhhhh. This quote is golden to me. I'm about to install an Avic Z110BT this week and didn't want to have to dig around for the speed sensor wire. This is a beautiful thing. Easy to access. I also didn't know if the angle chuck I saw at Home Depot (same type pictured here) was going to fit and work for me. Now, I can also see from your pics that it will. Beautific.
Old 03-02-2010, 11:27 AM
Black$heep
Black$heep's Avatar
Awesome! Glad it helped. Good luck with your install!!
Don't forget to take pics and share!!
Old 03-02-2010, 11:43 AM
Lancejoker
Lancejoker's Avatar
Looks great.
Old 03-06-2010, 12:38 AM
  #33
JMc
JMc's Avatar
I've since learned in a different thread that C5's do not have a VSS wire in the Bose harness. You actually tapped into something else, but apparently benign. Fortunately, the VSS connection isn't necessary for the GPS to function, but again, there is no VSS wire to the Bose harness in a C5, sorry to report. The only location for that wire that I've heard of to date is in the gauge cluster harness.
The right angle drill adapter IS available at Home Depot and mine was just $19. I drilled out the bracket today and will complete my installation tomorrow, hopefully, but I'd like to find an easier place to tap into the reverse light wire, hopefully, for the rear view cam.
Quick Reply: Pioneer Avic D-3 Install (lots of pics)
