08 VSS standard radio.......wire is behind the radio
Well, I finally got my D3 in the mail, and I decided to install it. Well, even though everyone stated the VSS wire is not behind the radio, as soon as I removed it, it is sitting there in the 12 pin harness. Checked it for continuity with my DMM at the ecm.
Just a heads up for those that will be installing a deck that needs the VSS wire, on a non-bose car
btw, the Metra GMOS-04 wiring harness is great. It not only has VSS wire in the harness (which I used instead of tapping the 12pin harness) but it also has reverse, and the brake wire
my only gripe.....the D3 is stating that there is excessive vibration....so I will have to go back in and somehow try to dampen it
That's good info, thanks!
To save folks a little of the Googling I just did... it's GMOS-04 not GMS-04.
http://www.crutchfield.com/S-tjrAGzG...px?I=120GMOS04
sorry that was a typo. I know these are more readily available than the peripherial ones
Make sure if you do buy the GMOS-04, make sure it has a date on it. Anything that has no date, or a date prior to 06/07
is a FAULTY UNIT!!!!!!!!!
there was a Metra send back on all GMOS interfaces last summer
