Sponsored by: DashLynx
add your system pictures here
Old 04-10-2008, 04:35 PM
lisoundsvette
lisoundsvette's Avatar
Default add your system pictures here
here are a few pictures of some of the corvette systems we did at L.I.SOUNDS
feel free to add your own pictures so others can get some ideas
and some other corvette systems we did
Old 04-10-2008, 04:37 PM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
we have a sticky for this already
Old 04-11-2008, 01:55 AM
cupidsrevenge
cupidsrevenge's Avatar
Beautiful door mount, what did you use and how the h^ll did you do it? Would love to put in a system with door speakers such as the second pic down from the top. Could you provide a parts list and simple how to instructions?
Old 04-11-2008, 01:44 PM
lisoundsvette
you can trace the original speaker pods onto a marine or fine grade plywood then mount you speaker set up to this a 6/4/tweet would work quite easy if you should choose a 8 /4 tweet then you will have to trim the door itself. after that dynamatt the doors both inside and around the speakers. mount your x-over i usually carve it into the styrafoam in the door pannel and run my new wires to the amps.
not to difficult just take your time good luck
To add your system pictures here
Quick Reply: add your system pictures here
