Just installed an isimple in an 01
And it was simple. The IPOD goes in the center console or wherever you want to put it. For those installing one, the dip switches are 3 and 8 on. The instructions scare you into thinking that you will have to strip power wires but you do not have to. You can use part of this link http://www.vetteessentials.com/instr...zel_howto.html to take out the radio. You don't need any of the cables that come with ISGM73 but you need a PXHGM4. It was easier run the PXHGM4 to the area behind the ashtray and plug it in to the ISGM73 so the radio fits back in. Just to add everything I learned doing this there is no radio security code. If anything I said above is wrong can someone correct me? Thanks.
