stereo questions - need help
I'm a newbie to this forum and had a few stereo questions(not newbie with stereo) cause i've never had with these issues.
1. stereo - last owner installed aftermarket stereo himself, but for the car to start have to turn on stereo first then can start car, and then the stereo has to be turned back on agian to listen to is and no preset are saved?? i figured that some wire must not have been connected, ya'll tell me.
2. stereo question again - looking to replace aftermarket stereo thats already in car (doesnt really fit and has cracked screen) but many of the aftermarket stereos has that the 8inch subs will not would is aftermarket stereo is installed? is that because they in an output from the back or do i need to run new wires to these for them to work?
If you wanted to pull the Bose out and replace it, then you would just need to run new speaker wire from the new HU to the new speakers.
Hope this helps.
Mark
