Sponsored by: DashLynx
Is there ANY multiple AUX input option for the C5
Old 07-21-2008, 08:37 PM
jrprich
jrprich's Avatar
Default Is there ANY multiple AUX input option for the C5
Does anyone have a solution that will add two or more AUX inputs to the Factory Bose Radio with the 12 CD changer in the back ?
I would like to be able to select my iPod or my Sirrius SAT Radio WITHOUT using a FM modulator.......so looking for RCA inputs.
I have tried the X3......won't work.
Looked at iPod2car but that only handles the iPod not the SAT Radio
Amazing that with thousands of Corvette C5s on the road, it makes one wonder why companies have not figured out a multi input solution for this huge market.
Yes I know I can change the HU,,,,,,,but I really don't want to go that route
Old 07-21-2008, 11:32 PM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
IMO best way would be to retain the changer how it is and wire in a relay to allow switching from the changer to an aux input. you could hardwire the same aux input to both the ipod and sirius and as long as you only had one or the other turned on at a time it would work great. Im trying to think of a way to wire a 3 way switch but off the top of my head i cant come up with it but im sure theres a way
Old 07-21-2008, 11:59 PM
jrprich
jrprich's Avatar
OK,
Possible solution......but getting expensive.
If you use an iPod then get the Peripheral iPod2Car PXDP $99.98
http://www.discountcarstereo.com/detail.aspx?ID=1162
Or
Peripheral iPod2Car (PXDP) Universal interface for iPod™ Product ID: PXDP
http://www.discountcarstereo.com/detail.aspx?ID=1056
Need the Peripheral PXHGM4 Harness for iPod2Car/Aux2Car in Select 1997-04 Corvette
$17.95
Then for the SAT Radio or other line level device get
Peripherals PX2X Secondary Input device for iPod2car/Aux2car $21.98
http://www.discountcarstereo.com/detail.aspx?ID=1048
Should work......but I have been there before and so far nothing has really worked
Old 07-22-2008, 12:21 AM
jrprich
jrprich's Avatar
I used this solution for a month, half way through a trip to Vegas it just stopped working......no CD Changer or SAT. When I got home I rewired it all and the SAT works now, but the changer is still on the fritz.
IF your sucessful, please Post so we can see what you did.
Here are helpful links if you want to try it......make you a deal on the parts, I now have 3 relays
All credit to MonteHall
http://forums.corvetteforum.com/show....php?t=1959059
even a wiring diagram
http://www.pqtsi.com/sedona/vetmp3.pdf
I modified this by wiring up a pair of RCA input cables rather than the 1/8" stereo socket
Parts list:
http://www.newark.com/
16M9048 1 In Stock 6.30 Plug-In Relay; Contacts:4PDT; TYCO ELECTRONICS
46F3589 1 In Stock 7.40 Relay Socket; No. of Pins:14; Socket Terminals:Screw; For Use With:KHA, KHS, and PT Series; Contact Termination:Screw; No. of Contacts:14 RoHS Compliant: Yes 27E894 TYCO ELECTRONICS
78H1411 1 In Stock 2.19 Rocker Switch; Illumination:Illuminated; Circuitry:SPST; Switch Operation:On-None-Off; Contact Current Max:16A; Switch Terminals:Quick Connect; Actuator Color:Red; Leaded Process Compatible:Yes; Mounting Type:Panel RoHS Compliant: Yes CR102J5RS215QF6 C&K COMPONENTS
Later I posted asking if anyone could figure out a double relay system based on the original and largodon
posted this but I haven't tried it.
"This should be very easy, you basically are just doubling up the relays from the normal aux in / CD changer mod seen here:
I mocked up a quick jpg to show how the 2nd relay would get added in.
the pin hookups are the same as the 1st link, the only changes are getting a second relay and getting a 3 position switch. You may need to experiment with which side of the 1st relay gets the green vs the blue wire (you want the blue wire to be on the 'no power' side of the relay). "
Old 07-22-2008, 01:44 AM
scott_fx
scott_fx's Avatar
http://www.wintektx.com/extras/making.htm
us the above in conjunction with the relay aux input and you should be good to go
Old 07-22-2008, 08:28 AM
pentavolvo
pentavolvo's Avatar
i have done similar things for customers and never had an issue at all
Old 07-22-2008, 12:52 PM
jrprich
jrprich's Avatar
I don't doubt, I must have an issue somewhere.........but I can't locate the problem. Replaced the relay twice, no change. Undid all the wiring, recrimped with new connectors, no fix.
Old 07-22-2008, 12:53 PM
jrprich
jrprich's Avatar
This looks great, but I doubt I have the soldering skills to build this......is there a commercial version ?? Or someone who builds these ?
Old 07-22-2008, 01:46 PM
pentavolvo
pentavolvo's Avatar
IMO you dont need the box just do the relay and split the rcas to both the ipod and sat radio, ive done this no isses before
if need be im sure i could wire up something for you
Old 07-23-2008, 12:55 AM
scott_fx
scott_fx's Avatar
after looking at your schematic briefly (missed it the first time); i agree with penta, that should work. the only thing that the mixer will add is if you eventually add a portable nav system or handsfree kit. you could hook that up to the mixer and have both sources play at the same time.
i bet they have a cheap mixer on ebay.
To Is there ANY multiple AUX input option for the C5
Quick Reply: Is there ANY multiple AUX input option for the C5
