Sponsored by: DashLynx
Wiring Cd player in problem
Old 12-31-2001, 05:28 PM
Admiral blue x 2
Admiral blue x 2's Avatar
Default Wiring Cd player in problem
I have a 94 and i have found and wired the black wire to the ground one, the pink one for the power antenna to the blue one on my harness and the orange wire to the red wire on my harness but i can't find a yellow wire for the ignition to wire my yellow one to thats on my harness... I have tried a red wire with a white stripe down it and a purple wire but neither of them seemed to work when i turned on the car, I still have a Brown, Black, and a green one with a stripe down them and a solid green one that i haven't tried on the main plug from the old bose... which color wire is the ignition one that i should be wiring to, since there isn't a yellow wire anywhere??? thanks
Old 12-31-2001, 06:40 PM
Dave84/76
Dave84/76's Avatar
Default Re: Wiring Cd player in problem (Admiral blue x 2)
I will assume that you have extended the wires to the pass. side well behind the seat. If so, this is what you should have:
radio black to black in car.
radio yellow to orange in car.
radio blue to pink in car.
radio red to yellow in car.(some later GM's used a green for acc 12v)
Quick Reply: Wiring Cd player in problem
