Ipod w/XM Commander and stock radio?
I've read a lot of threads and didn't find any with my setup and an Ipod.
I've got the Cor-Har wire harness with a GM Aux 10 connected to a XM Commander radio with my stock GM Radio.
Now I want to add an Ipod with direct hookup.
What do I need to make this work?
All the threads I have read use my setup with IPod but I want both.
i would get 2 Y adapters to split the rcas, run one to xm unit and the other to this cable
http://www.sonicelectronix.com/item_...abilities.html
provide it with accessory wire and bam will charge ipod and pipe the sound through, to me it seems liek ur best bet
Thanks, that makes sense and I would only need to cut off the XM Radio when I play the Ipod and vice versa.
correct in theory you could leave em both on and they would both try to play
imo this is the best way to go because im not sure how an ipod2car and the aux adapter would interfact together, and the ipod2car is garbage esentially because you basically have to do all controls from the ipod because the radio cant control it worth jack
