C6 w/pioneer avic z2 static/hiss
Old 10-26-2008, 09:46 PM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
i doubt running a ground will fix it, but try running ground to oem amp
otherwise i would try the rca fix i linked
Old 10-26-2008, 10:01 PM
philip_g
philip_g's Avatar
I tried the RCA fix and it actually made it worse. I disconnected it tonight and it's probably 60% better. I'll try to ground the OEM amp tomorrow.
I had all four RCA's grounded together to the same ground as the HU, it got worse, I tried a temp cable to the bat negative and it was just as bad so I pulled those out. I also tried connecting them to the Z2 chassis, no change.
I could try better isolators ifgrounding the factory amp doesn't help.
Old 10-26-2008, 11:40 PM
pentavolvo
pentavolvo's Avatar
i wonder if the isolators combined with the ground fit cancel eachother out or something
with that said i have never had noise on a single c6 with aftermarket unit
Old 10-26-2008, 11:44 PM
philip_g
philip_g's Avatar
there are so many variables in the system who freaking knows.
could be a bad GMCO, a bad HU, a bad amp, some crappy wiring that I did, all I know is that if I have to take the dash apart one more time
I thought DC'ing the RCA grounds had knocked out all of the alternator whine so I put it all back together and it's BAAAAAAAaaaaAAACK.
Old 11-01-2008, 08:56 PM
philip_g
philip_g's Avatar
so after:
grounding the RCA's at the HU (made much worse)
grounding teh RCA's to the HU chassis (same)
grounding the HU chassis to the battery (same)
routing all the system grounds to one location (the battery -)(same)
grounding the factory amp (no change)
all I can think to do is since the problem started when I switched from speaker level outs to low level, get a quality line level converter and wire it in, I can't think of any other simple solutions.
Old 11-17-2008, 11:22 PM
philip_g
philip_g's Avatar
a peripheral 4ch line level convertor fixed the alternator whine, I ditched the ground loop isolators, don't need 'em anymore.
there's still some base level hiss but it's not that bad, maybe the factory amp is crap, I don't know.
Hey do your back speakers sound really "tinny"? I can't remember if they sounded crappy before or not, doesn't matter as you can't notice anyway.
Anyway, I've ome full circle only to land right where I started
Old 01-03-2013, 04:55 PM
philip_g
philip_g's Avatar
god dammit.
So I had this problem with my 07. I recently bought a '10 with almost the same setup, just a newer AVIC H/U and whaddayaknow? HISSSSSSSSSSS
Old 01-15-2013, 08:50 AM
crAzy
crAzy's Avatar
Im having the whine and slight hissing in my 06 Z with aftermarket speakers/amp. Its annoying.
Old 01-15-2013, 11:00 AM
philip_g
philip_g's Avatar
It is isn't it? I think I'll just run an aftermarket amp and subs and do away with the factory everything
Old 01-15-2013, 12:28 PM
markcz
markcz's Avatar
Try putting one of THESE between the car plug and everything you have powered by the oem 'radio' fuse. For $10 and an hours work it's worth the effort if it works
Old 01-24-2013, 10:05 AM
philip_g
philip_g's Avatar
the whine isn't alternator noise, it's present even with the engine off.
Old 01-24-2013, 10:27 AM
crAzy
crAzy's Avatar
I found my fix for alternator whine and hiss. It was the (-) ground being on the battery terminal. So I moved it to a chassis ground and fixed everything. But doesn't stop there lol. My amp is bad. Overheats with just my rear speakers plugged in.
Old 01-24-2013, 08:02 PM
  #33
philip_g
philip_g's Avatar
for the HU or the amps?
My assumption is the HU is grounded through the wiring harness, but I seem to remember re-grounding the last car and not seeing any improvement, I'll check it out though
Old 01-24-2013, 08:20 PM
  #34
Rayzzz
Rayzzz's Avatar
Default Wires
Make sure you have all your speaker wires and RCA's are ran separate from other wires. I tried all kinds of stuff and then separated the wires and problem gone.
THANKS RAYZZZ MY CORVETTE LIKES MY MONEY
Quick Reply: C6 w/pioneer avic z2 static/hiss
