Sponsored by: DashLynx
Hmmmm-new deck sounds worse
Old 07-06-2009, 05:35 PM
psxer989
psxer989's Avatar
Default Hmmmm-new deck sounds worse
I changed out the deck on my 2002 C5 with a PA 5300. I kept the stock speakers. I used the wiring adaptor and Sven2 to hook it up. Pretty simple install....however, the sound blows. I know that the Bose needs to go, but until then I wanted to get some input to see if I'm missing something with this setup. At the normal bass and treble settings, I get a ton of distortion from the subs (no crisp bass). I had to turn the bass way down, but that leaves me with no midrange or low bass. Did I hook up something wrong or does the PA 5300 require real speakers? It was such a simple setup I can't see how I messed it up.
Larry
Old 07-06-2009, 06:10 PM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
Pa5300?
Old 07-06-2009, 06:15 PM
psxer989
psxer989's Avatar
Power Acoustik's 5300.
Old 07-07-2009, 07:05 PM
wildwall
wildwall's Avatar
Larry
Both switches on the SVEN2 should not be in the rca position. At first it sounds like you get more bass that way, but it is actually distorting.
Old 07-07-2009, 08:48 PM
psxer989
psxer989's Avatar
I followed the instructions, but I can't remember the switch positions. I'll take it apart and check it. Thanks for the help!
Larry
Old 07-11-2009, 12:50 PM
psxer989
psxer989's Avatar
The Sven2 has one switch for the input (rca/wired) and one for output(rca/wired). Playing with different combinations made no difference. Both rca, both wired, one rca and one wired...I'm still just getting a distorted subwoofer sound that dominates.
Old 07-11-2009, 05:49 PM
pentavolvo
pentavolvo's Avatar
how is ur eq/loudness set up on ur headunit and the switches should make a difference u want wired in rca out
Old 07-11-2009, 06:31 PM
Vette-kid
Vette-kid's Avatar
Doesnt that adapter bypass the factory amps? a HU with no amp is going to sound pretty crappy.
Old 07-11-2009, 08:31 PM
psxer989
psxer989's Avatar
This hu just has treble and bass adjustments. I have both set to midpoints. I'll double check my rca switch setting to verify.
Old 07-11-2009, 08:47 PM
psxer989
psxer989's Avatar
Ok, it sounds better. Not great, but better. My rca/wired switches were backwards. The HU also had a subwoofer setting set to OFF. I turned that on for the hell of it and the sound is balanced better. I guess I'll be buying an amp and speakers soon.
Thanks for the help,
Larry
Old 07-11-2009, 11:48 PM
pentavolvo
pentavolvo's Avatar
the sub seting on the headunit should have zero effect on anything. and u can adjust the door subs via the adjustment screws on the sven2, keep them equal
Old 07-12-2009, 01:12 AM
psxer989
psxer989's Avatar
That's what I thought. I did the adjustment screws but can't really tell any difference. I just set them about mid-travel.
Larry
Old 07-12-2009, 03:15 AM
pentavolvo
pentavolvo's Avatar
honestly unless ur deck is garbage it should sound better then stock never have i had it been worse
To Hmmmm-new deck sounds worse
Quick Reply: Hmmmm-new deck sounds worse
