thinking aboud adding a 2nd amp, question about wiring
im thinking about adding a 2nd amp this winter, either a 3 or 4 channel. i want to run my 4x6s off it (polk momos 40wrms @4ohm) and possibly add in a 10 inch sub.
i currently have an xtant a4004 running my bi amped momo 6x9s. ive got 4 input and 4 output rcas on the amp.
can i run all 4 inputs plugged in, and run the outputs to the 2nd amp?
would there be any issue with running my 6x9s off both amps? id like to use my HUs time alignment. keep the woofers on the rear output of one amp, and hook up the tweeters to the rear output of the 2nd amp and then run the 4x6 off the front. (rather then how i have it right now, woofer to the rear, tweeter to the front, 4x6 off the Hu)
