C5 Bose head unit installation Metra 70-2004 vs Metra XSVI-2004
8th Gear
Hey guys, I'm replacing my OEM head unit in my 99' C5 with a Pioneer DEH-P3100 and I'm confused at which wiring harness to get. I was told by one installer that all I would need is the Metra 70-2004 and he can set it up to work with my BOSE speakers. However, other installers told me that I need to get the Metra XSVI-2004 adapter in order for the door speakers to work properly. Does anyone know if the Metra 70-2004 would work as well as the XSVI-2004?? Thanks!
i wouldnt dick with the 70-2004 as an installer i have done it and spliced some wiring to get everyhthing working... just spend the money and get xsvi-2004 or even better pac roemvet1
Former Vendor
You will need
the roem-vet1
http://www.doubledmods.com/C5-Corvet...-ROEM-VET1.htm
GM antenna adapter
http://www.doubledmods.com/1988-2010...dapter-gm6.htm
installation kit
http://www.doubledmods.com/Corvette-...-kit-BKGM4.htm
the roem-vet1
GM antenna adapter
installation kit
OK, I've been waiting for Metra XSVI-2004 for some time now because all of the vendors I have contacted are back ordered. The Mfgr is waiting on circuit boards from Asia. I have been thinking of going with the roem-vet1, but several vendors say that you will lose your tweeters with this interface. I contacted Pac and they also said that was the case because the tweeters are powered by the radio. So my question to those of you who have used the roem-vet1 interface; have you noticed a loss of high frequency sound from you radio?
Phil
Phil
8th Gear
phil, I just installed that roem-vet1 and I think the highs sound fine even without the tweeters. However, I have noticed that my door speakers aren't kicking as hard as they were before. It might be a bad installation though. Does anyone else have this problem?
8th Gear
Thanks for the info Jon. I brought my car to Sound Blazers in Coral Springs, FL and they told me that my install was fine. They also said that the bose speakers are not going to sound as good with an aftermarket head unit combined with the factory speakers and amp even with the adapter. They then tried to sell me a new amp and speaker setup. Do you all think that they were trying to take me for a ride?
8th Gear
I honestly don't think so. It sounds loud like the highs and mids are working but I'm not getting as much bass as I did before. I don't know if I have a bad adapter or just a bad install.
You have to VERY carefully adjust the POTs on the silver box (about 1/16th of a turn at once) to get the BASS to work. It took me three itterations from zero to 1/8th turn and then to about 1/5th turn for the front and 1/4 (total!) for the rear. Sounds great, better bass than stock and no noise/static/popping (which is what will happen if you hamfist the pots.
However, I can't at this time remember if I have an Axxess or Metra adapter.
The Metra adaptor has a black plastic box and a silver one. They are attached to two stock wire blocks. The silver box has four potentiometers (these look like screws) to adjust the BASS. Just find the silver box and tweek the screws a very little at a time, play your favorite ZZ Top tune (or something with a beat) and go from there. Cheers
Okay,
Okay, I just added a Sony head unit using the Metra Axxess XSVI-2004 and have lost the RAP function - does not turn off when ignition is off and doors are opened. I will be on the phone with Crutchfield tomorrow. Documentation on the Metra unit is terrible - almost nothing.
Anyone dealt with this problem and found the solution?
The PIONEER unit requires a POSITIVE (tan/white) source from the parking brake, some H/U need a GROUND (don't know what color) from the parking brake. Weird and wacky stuff happens if you don't connect this IAW the H/U directions.
