Sponsored by: DashLynx
Can I hard-wire a GPS power cord into my rear view mirror?
Old 09-20-2010, 07:06 PM
swimdog82
swimdog82's Avatar
Default Can I hard-wire a GPS power cord into my rear view mirror?
I really like my GPS mounted to the right to my rear view mirror on the windshield, but i can't stand the power/traffic cord hanging down. Can I hard-wire the GPS power cord into my rear view mirror? I have a '98 A4 and the rear view mirror is not an auto dimmer. The GPS is a Germin nuvi 1390t.
I was thinking about use using a female adapter or something like this.
http://http://www.mountguys.com/prod...garminnuvi.htm
That way I wouldn't have to cut the GPS cord and I could still use the GPS in my other vehicle. Plus I don't use the GPS everyday, only on long trips. So the extra cords would just be mounted to the back of the mirror to keep them out of site.
I really want to avoid hard-wire it to the fuse block and run it up the A-pillar.
The rear mirror seems like it should work but I'm not sure if the mirror would have the right power output. Any input would help.
Thank you
Old 09-20-2010, 07:49 PM
Knob Jockey
Support Corvetteforum!
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
How much current (in Amps) does your GPS pull? Check the paperwork that came with device for it's specs and fuse rating.
Detectors draw very little but your GPS/screen may require quite a bit more.
Quick Reply: Can I hard-wire a GPS power cord into my rear view mirror?
