best drop in speakers for C6 bose system?
Go Fast
Very interested in the final out come of your install and your thoughts on the Polks. I am thinking of the same combo as a temp system upgrade while I get my permanant system together.
last i checked dealer literally wanted a small fortune. if its the thumb tacks u gotta take off to pull panels for rear speakers i just might happen to have a box from some fastner website they look identical to gm ones i can mail u a few if need be
yes its those exactly, what about gm partshouse...how much can they possibly be...i only need 2
Well, you talked me into it. I'm ordering some myself. I already have a sub added to the factory system so these should make the system good enough to my ears.
#34
#35
i guess im gonna have to take you up on that offer, i can send you paypal or something, my local dealer wants 5 dollars each and they don't even have them.
#38
Just installed my fronts and wow a big difference! Install went flawless, no broken clips or extra parts!
I ended up keeping the stock wire harness clips just in some strange case I feel like putting the stock speakers back in the car. I just removed the blue clip from the stock speakers and soldered it to speaker wire then soldered it to the new speaker. Pretty clean install. Both clips are the same (back ones might be too) instead of wasting time with a color wire diagram just use this pic
Here's what my speakers with the clip connected looked like
I put a little bit of foam around the blue clip before reinstalling the door panel to make sure it didn't rattle around back there. Speakers sound great. Install took about 2 hours and that includes running up and downstairs to solder (stupid garage doesn't have an electrical socket ). Started with intentions of taking the top off and listening to my new speakers because it was bright sunny and warm and 2 hours later when I finished the clouds had rolled in.
Now it's raining. No Vette today Have to drive this bad boy.
#40
