best drop in speakers for C6 bose system?
#61
i was planning on just removing the sub and installing some 6.5" alpines and new tweeters in the door! so when u say the stock amp, are u referring to the watts the stock head unit is pushing out to the door after i remove the powered sub? i honestly dont want to go threw the hassle of installing a 4 channel amp and rewiring everything just for the doors.
so if i just do the swap from stock powered bose to aftermarket 6.5" in door would the sound quality be better or same (i dont care to much about bass in the door)? im also installing new rear speakers and a 10" sub in trunk if that makes a difference in how u think it would sound?
Removing the oem door subs and twiddler to install 6.5" component set is a great improvement if you use an aftermarket amp to power it. If you just hook up the oem twiddler feed to the new components it will sound anemic
#62
Another option:
Get new kenwood headunit,
Run new wires from the headunit speaker wires harness to the new 6.5" and tweeter components in the door with out adding an amp, how would that sound? Since u won't be using the low frequency wires from the stock 10" bose base amp, I would think the sound would be a big improvement..true or false
#63
Another option:
