Issues with OnStar, Z130BT and PAC OS2Bose
I am having an issue I hope someone here has encountered and resolved.
I have an 08 Coupe and I just installed a Pioneer Z130BT. I am retaining the Bose AMP/Speakers. Dennis at Double D did the prewire of the PAC OS2BOSE and harnesses. I completed the in-motion bypass and the final integration of the wires for an Axxess steering wheel control interface. As indicated by PAC I cut the Brown looped wire at pin 16 and attached it to the radio's Mute wire.
With the radio on I press an ONStar button and the radio mutes and I hear the OnStar prompts. Within a second the rear speakers kick back in and I must manually lower the volume to get them out of the way. Also, the radio nor steering wheel volume controls have any effect on OnStar.
With the radio off I don't have any speaker issues, but I also have no volume control.
Has anyone run into this issue? HELP!
radio and steering wheel controls will not effect onstar volume they must be adjusted from the module before buttoning up the dash
if its not staying muted it sounds like an issue with your wiring
Former Vendor
I didnt connect the mute wire as its needed for the bypass on the 130
i know pioneer has an issue right now with the steering wheel controls and volume.
They are working on a new software upgrade for this.
if you did connect the mute wire did you connect to pin 16 i think it is off the top of my head
if not reconnect the brown loop wire and try it
As for the Pioneer issues with steering wheel controls, the Axxess interface is working 100%. All buttons active and working as intended.
Last edited by miami08VETTE; 04-10-2011 at 11:21 PM. Reason: additional info added
Former Vendor
The PAC website says to cut the brown wire at pin 16 and connect to mute wire from radio. So it ends up being the brown wire coming out of pin 18 goes to the radio mute wire as I understood the diagram and instructions. That is what I did. So now the door and center speakers are muted when OnStar is pressed but the rear speakers kick right back on within a second or so.
what did you do for the bypass then if you connected the mute wire?
the mute wire gets moved for the bypass so you can not connect it to the pac harness
yellow black mute light green and black ground go to black ground on pac
just leave the brown mute looped and this should take care of it
if you connected the yellow black mute wire to the pac then thats the problem as we moved the wire for the bypass
On my 08 setup Pioneer Z120, granted with out Bose and with a external amp so it's a little different. I cut the brown mute wire but since I did the motion bypass using the mute pin I could not hook the brown with to anything so I left it unconnected, but cut, and it work's fine. But, what I did was to unconnect the center speaker and not use it as part of the stero its only use is for onstar. I unconnected the connector to the center speaker and soldered two wires to the speaker and then connected them to the output from the HU and I love the sound and ON Star works great. I don't believe the center speaker offer's much to the sound of the set up in fact it makes the balance and fade hard to setup. You may want to think about this for your set up.
Dennis helped me to work this out and the PAC instructions actually tell you to use this set up if you are hooking up an external amp.
When I leave the wire looped it does a full shutdown of the radio followed by a reboot when OnStar session is over. I really didnt like that functionality.
It sounds like I have to choose between the bypass or having a properly functioning mute feature?
Former Vendor
I used an in-line tap connector to attach the brown wire to the radios mute wire. From what you mention here that shouldn't work, although it does mute everything except the rear speakers. That is what is confusing me because it partially works which I can't explain.
just reconnect the brown looped wire and you will be fine
problem is we moved the pin over for the mute wire as well so its not in same place to allow it to mute
Any idea why it is doing a partial mute in the config I currently have (decribed in my last post)?
Former Vendor
Dennis the issue when the brown wire is looped is that it does not mute the radio. It shuts it down. When I am done with OnStar it has to reboot complete with having to hit the "ok" button at startup.
This sounds like something for Pioneer tech support i am thinking
only issue is when you talk to them you can not mention the bypass or they will not help you
trust me on that one as I have called before.
The pac harness we have in past never cut the looped wire and it works fine
anyone else have any ideas?
re the rears not muting with everything else, sounds like an issue for Pioneer to figure out
re the bypass vs mute, is it possible to do both? Connect the mute wire in the normal location, then connect a different wire to the 'new' location that does the bypass. Just a thought.
If it comes down to not muting the rears vs shutting down unit, how many calls do you take in your car? I think I'd go for the shut down option, my 920 reboots in under 5 seconds and if you're on a music screen you won't have to hit OK until you switch over to nav.
re the bypass vs mute, is it possible to do both? Connect the mute wire in the normal location, then connect a different wire to the 'new' location that does the bypass. Just a thought..
This is exactly what I was going to but when doing this I discovered that cutting the brown wire was all I needed to do.
[/QUOTE]If it comes down to not muting the rears vs shutting down unit, how many calls do you take in your car? I think I'd go for the shut down option, my 920 reboots in under 5 seconds and if you're on a music screen you won't have to hit OK until you switch over to nav.[/QUOTE]
On my Z120 we went thru this same issue, mine works by shutting down and restart after a onstar call
I have the bypass installed by moving over the pin in the connector
My brown mute wire is cut but not hooked to anything
I know I have a amp and speakers but I had the same issue, cut the brown wire and see if makes a difference.
Not sure about only the rears when mine was on a onstar call all the speakers we on.
Not sure about only the rears when mine was on a onstar call all the speakers we on.[/quote]
Some good suggestions. For now I will leave it as is. I have everything put back together and I don't want to tear it up for round 3. At least not for now. Everything else works so I will just lower the volume on the rears when I need to use OnStar phone.
Thanks!
Thanks![/QUOTE]
Enjoy I love the tunes up.
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
I'm a little confused on the bypass stuff. I have a AVIC 110 that has been upgraded to 120 and now to 130, and the original bypass no longer works. Can someone provide direction as to my steps to rectify this?
Thanks, Clint
Thanks, Clint
