C5 speaker buzz
C5 speaker buzz
I have a stock C5 vert with very low miles and a few months ago the driver's side speaker started to make a very annoying buzzing sound. I imagined it was a split in the speaker surround or a hole in the speaker material. Yesterday I decided that I would take the door panel off and investigate. I removed the bass speaker and examined it and found nothing wrong (visually) and reinstalled it. I powered up the stereo and low and behold the noise was gone. I cranked up the volume and no buzz. I also examined the metal grill on the door panel and it seemed loose. So, I pushed the tabs down tight and thought that buzz might have come from a loose tab or loose grill. Feeling really good about "fixing" the issue, I smugly reassembled the door panel and went for a test drive with the top down and my favorite CD. Crap! The buzz was still there. Any ideas? Anyone had similar finding? Is it possible that the speaker is bad and it just doesn't make the noise when the door panel if off? I am going to remove the panel again today but thought I would throw this out to the forum for ideas. Many thanks for any suggestions.
Does it do it with certain songs with lots of bass?
I have the same problem but on the passenger side and I don't have buzzing when the actual door panel is off so mine is related with the actual door panel.
I think I know what my issue is. Two of the door panel pins on mine broke while installing an aftermarket 3.5" speaker. I ordered a dozen of them for future use.
Does yours vibrate or buzz when you have the door panel off? Find a song that it buzzes with and try it with the door panel off.
With the door panel off the bass is tight and does not create any buzzing sound so it almost has to be in the panel or door. Was thinking of making an isolation gasket between the speaker and the door panel but not sure if that would do anything. Thanks for the thoughts. I will keep trying to find something.
