Sponsored by: DashLynx
Kenwood 9980 and Mild to Wild
Old 05-15-2011, 09:09 PM
FerrisB
FerrisB's Avatar
Default Kenwood 9980 and Mild to Wild
Hey All. Just wanted to share with you a cool trick you can do with the Kenwood 9980 (as well as other similar HU). I recently installed a kenwood 9980. With this unit you have the option to set up auxiliary devices. Using the link below I setup my mild to wild to be controlled via my stereo. Very cool stuff. Enjoy
http://dfwcorvettes.com/dnx8120install3.asp
I own a 2008 C6 Coupe
Old 05-15-2011, 09:41 PM
NASTY ZO6
NASTY ZO6's Avatar
That is cool! Thanks for the info!
Old 05-18-2011, 09:26 PM
chevyc6z51
chevyc6z51's Avatar
does anyone know if this can be done with avic units?
Old 05-22-2011, 03:09 AM
chevyc6z51
chevyc6z51's Avatar
Old 05-22-2011, 09:26 AM
markcz
markcz's Avatar
Pioneer units don't have connections to control other devices
Old 05-23-2011, 03:46 AM
chevyc6z51
chevyc6z51's Avatar
awwwww, any by pass on this? or is it just a dead end?
Old 05-26-2011, 03:23 PM
chevyc6z51
chevyc6z51's Avatar
anyone??????????
Old 05-26-2011, 03:59 PM
markcz
markcz's Avatar
Anything is possible if you're willing to put enough time, effort, and money into it. The only way I can imagine doing it would be to buy a CD changer (or some other external accessory) that you can gut and use as a trigger to turn on a relay controlled switch. Rig the relay circuit to stay on after you de-select the changer, but then have it go off if you select changer again.
Old 05-26-2011, 04:58 PM
Bonefishmak
Bonefishmak's Avatar
Old 05-27-2011, 04:13 PM
Bonefishmak
Can this be done with a Kenwood 9960??
To Kenwood 9980 and Mild to Wild
Quick Reply: Kenwood 9980 and Mild to Wild
