Please check my planned wiring diagram.
Supporting Vendor
This is a basic outline of how I plan to wire the components of my sound system. Please let me know if I missed anything and if the wire routes look good.
Application: 2002 Corvette Coupe
Source:
Alpine IVA-W505
Processors:
Alpine PXA H701 Setup for 3-way front stage active x-over (no rear channel)
Epicenter 150 Subwoofer Harmonics processor….just for fun
Amplification:
(2) Alpine MRP-F300 (one left and one right channels)
Channel 1 – tweeter
Channel 2 – Midrange
Channel ¾ (bridged) Mid bass
JL 500/1
Drivers:
SPX 107r Midrange/tweeters
SPX 17MB Mid bass
JL 12w6v2 Subwoofer (sealed custom box)
Planned passive acoustics:
Second skin “Damplifier” sound deadener
Second skin “Luxury liner Pro” Acoustic foam
Source:
Alpine IVA-W505
Processors:
Amplification:
Channel 1 – tweeter
JL 500/1
Drivers:
SPX 17MB Mid bass
Supporting Vendor
I would run the ground wire from the amps all to a common ground. Preferably the mid bass amps grounded wherever the sub amp is grounded (with large gauge wire). The fewer the groung loops the better.
Supporting Vendor
In that case, would I do better to extend the ground from the amp rack to the Frame ground in the rear bumper or extend the sub amp/power converter ground to the passenger seat bolt?
Former Vendor
the yellow top sucks
i went through 3 of them in 2 years with nothing but issues with my setup. Battery was always dead
took the 3rd one back they gave me 100.00 back and an AutoZone Gold and never had any issue since
save the money and skip to Yellow Top
Former Vendor
Supporting Vendor
Most of the components listed have are transferring over fro my old car. All i need to get are the head unit, H/O alternator and various wiring components.
Regarding the ground issue, I think I'm going to ground on the frame in the rear. This makes it easier to take the seat out if/when I drop something between the seat and tunnel I can't reach.
Former Vendor
I would except I already have it. Compared to my old red top, I have have no problem with it over the past year.
AutoZone stopped carrying yella & red tops (for obvious reasons) ... the rest looks great -except tweets should be on the A-pillar, easy with a flush ring in the flat spots (atchd) ...
Source:
Alpine IVA-W505
Processors:
Amplification:
Channel 1 – tweeter
JL 500/1
Drivers:
SPX 17MB Mid bass
Source:
Alpine IVA-W505
Processors:
Amplification:
Channel 1 – tweeter
JL 500/1
Drivers:
SPX 17MB Mid bass
Supporting Vendor
do you already have the f300s. i was looking at that amp but i found the f30 was of better quality. only about $75 difference in price each. also curious about the sub box, is it going in the back facing toward the front? were you going to remove the trim panel to fit? and last, will you still be able to take the top off and store in the back?
Sub box will be facing straight up sitting inside the cargo bin for maximum use of the cargo space.
The top will be store-able in the cargo area.
it was total harmonic distortion. f300 is rated at 1% and the f30 is rated at .08%. you probably can't hear the difference but anyway, i found that info on the alpine website. i remembered from buying audio equipment for the home how manufacturers rated their amps and i also remembered that car electronics were never as clean as home audio. no big surprise there seeing as a home system doesn't have to deal with heat, vibration and small size. with the lower THD, you can really turn it up and not worry about it breaking up.
Supporting Vendor
