SALE: Peripheral GMAH24 + GMAHCM + Metra 40GM10 (allows aftermarket radio install C6)
These are out of my C6 and used but in great condition.
* These three adapters will allow the installation of an aftermarket radio into your C6. *
Note: These adapters are only used if your stock setup is Bose + Onstar. If you have non-Bose or non-Onstar, then you will need different adapters.
Included:
- Data Bus Interface: Peripheral GMAH24
- Chime Module: Peripheral GMAHCM
- Antenna Adapter: Metra 40GM10
Price = $70 + FREE Shipping
For more info on installation please check out the C6 Audio Section:
http://forums.corvetteforum.com/audi...-write-up.html
Specs:
The GMAH24 is a plug and play interface that allows replacement of a General Motors Class II factory radio and maintain operation of the OnStar system. The GMAH24 has on board switching, and amplification to allow audio from the OnStar system to play through the two front factory speakers when OnStar is active, and mute the new replacement radio.
Retains door chimes when used with PERIPHERAL’s optional GMAHCM chime module. The GMAH24 can also be used when a radio and amplifier combination system is installed. Separate speakers can be added if desired.
GM vehicles with Class-2 radios with OnStar and Non-BOSE sound systems or BOSE sound systems when not retaining factory BOSE amplifiers. The GMAH24 decodes chime signal commands on the Class-2 data-bus and supplies the appropriate warning tone (door ajar, seat belt, low oil pressure, hi-temp., low fuel, headlight, etc...) through the OE amplifier, external speaker, or through add-on chime module GMAHCM.
Provides an effortless and seamless head-unit installation into late model GM vehicles while retaining complete operation of OnStar!
Generates 12-volt accessory output & retains RAP function
Uses genuine Delphi chip for seamless integration
Provides “Healthy Status” report to the Class-2 system
Does not retain factory satellite.
Peripheral GMAHCM (retains chime functions)
Peripheral GMAH24 (provides healthy status to computers)
Metra 40GM10 (antenna adapter)
Included:
Specs:
