How to mount amp behind passenger seat?
I just removed the passenger seat in preparation for my install. I've decided to do it myself. Never having done any car stereo installation, I'd appreciate any advice. There will be more questions for sure. The amp is Arc Audio xDi805. Should I fasten it to a plywood board, then the board to the metal body of the car? Or amp fastened directly to the metal? What size bolt should I use to go through the metal?
Thanks,
Thanks,
An outfit called parts express has "hurricane Nuts".
http://www.parts-express.com/pe/show...umber=081-1082
No afiliation, just a long time customer. Other sizes available. Epoxy into place.
Worked great for fibreglass boat but you may need a nut-sert if you are going into metal. Works like a rivet, but has threaded center. Installs with a rivet gun and a stem tool to bind it home. Perhaps Swingline tools still has them.
More expensive but higher quality is "Marson" -- see thread setter kit #39214
Grainger is a source for that one.
Before all the fancy tools, we used to take the teco straps you get at Home Depot and Lowes, ace hardware etc.and braze nuts onto them. Then glue the strap with epoxy and tighten the amp into place. If it worked -- (the glue held), when you took it apart, the strap and nuts stayed.
Last resort was a piece of pipe strap and clip on speed nuts.
Parts express is a good source for a lot of electronics supplies.
TDCVA
TDCVA
Your gas tanks are right behind the panel where you would be screwing into, so you do not want to drive any screws into that area.
Put the board in place, resting against the floor panel, and apply some liquid nails, and the board won't go anywhere. Place the carpet over that, and mount your amps (using the appropriate length screws) and you're set.
I'm getting ready to mount my EQ (AudioControl DQXS) there and was planning to epoxy four 1/4" x 1" elevator bolts to hold it (attached, from Ace hardware), cutting off any protrusion once bolted to. The bolt head is pretty wide and should stay in place. Maybe this is a better solution than the plywood and will have minimal thickness.
On my C5 I had 2 amps there, short-screwed to a 1/4" plywood piece held in place with liquid nails. Good luck and post a pic of how it turns out ...
May not work to well for a amp because of the heat, but anyway. I installed my XM receiver behind the passenger seat and I just put it under the carpet flap folded the flap back down and left it like that, no board mounting or anything, its been there for about 1500 miles and not one issue nothing, it may be too hot with the carpet over it for a amp but it sure works good and simple for the XM receiver.
Good Luck, DO NOT DRILL ANY HOLES IN THE PANELS BEHIND THE SEATS.
I'd recommend click studs. We use them on our aircraft to hold almost everything down. Could peal the carpet back, mount them to the metal and have them poke through. This will also give you more clearance for the seat instead of having a block off wood there as well. Pretty much what Thrash was recommending. You can get these and epoxy from a bunch of different suppliers. I have the amps in my truck mounted behind the back seat with these.
Update to my original reply, I removed my XM box and put my new amp behind the seat under the carpet with out mounting it to anything, it has worked great for two years with no issues. IMO no need to attach the amp at all.
