Sponsored by: DashLynx
Dimmer on C6 and Pioneer Z130BT
Old 12-03-2011, 07:04 PM
MO POWR
MO POWR's Avatar
Default Dimmer on C6 and Pioneer Z130BT
Trying to install a Pioneer Z130BT in a 2011 GS. I can't get the dimmer to work. I have tied the orange/white wire from the HU to the Gray/Black on the traction control button as I've read in other posts and still cannot get the HU to dim or go into night mode when the headlights are on. Any suggestions?
Old 12-03-2011, 07:17 PM
markcz
markcz's Avatar
Is it dark outside?
The dimmer circuit doesn't exactly operate in conjunction with the headlights, it uses it's own sensor (I believe on the dash near center speaker, but not sure about that).
Old 12-03-2011, 07:47 PM
MO POWR
MO POWR's Avatar
No it wasn't dark outside. I just assumed that it would dim when I turned the lights on manually.
Old 12-12-2011, 03:47 PM
raydawg357
raydawg357's Avatar
You have to catch the dimmer wire from behind your HVAC controls. It should be yellowish or cream in color. Test it with a DMM to be sure.
Old 12-12-2011, 06:35 PM
markcz
markcz's Avatar
In C5 yes, C6 no
Old 03-12-2014, 09:33 AM
Woodyt38
2nd Gear
Woodyt38's Avatar
Default Pioneer AVH-X5600BHS
I have connected the dimmer wire to the traction control but it's stays dim all the time now. I can only manually control the brightness. Any thoughts?
Old 03-14-2014, 07:40 AM
LT1 Z51
Corvette Enthusiast
Support Corvetteforum!
LT1 Z51's Avatar
You might be on the wrong dimmer wire.
Mine works fine. And yes on the C6 the dimmer is not the same as the headlamp. Interior lights are independent of exterior.
Old 03-14-2014, 11:43 PM
Wampa
Wampa's Avatar
just dealt with dimmer issue on my c6 Monday. had wired GMOS4 adapter properly and dimmer did not work. 30 mins with Crutchfield tech support resulted in solution. Tapped wire on HVAC controls to radio harness orange/white illumination wire. Works properly now. There are three harnesses connected to back of HVAC. You want the right most (closest to passenger) harness. looking at female side of harness, tap the gray/black stripe wire in the right most(passenger) lower corner of connector. I'll find the pic...says a thousand words...
Old 03-14-2014, 11:49 PM
Wampa
Wampa's Avatar
Old 03-15-2014, 07:38 PM
markcz
markcz's Avatar
The gray/black wire on the traction control button is the same circuit as the gray/black wire on the HVAC, either should work.
To Dimmer on C6 and Pioneer Z130BT
Quick Reply: Dimmer on C6 and Pioneer Z130BT
