What to Do? Kenwood DNX 9980 or new DNX 9990
Last week I was set to replace the Bose/nav in my 07 Vert with the Kenwood DNX 9980 when I heard that the new DNX 9990 was coming out. So I waited.
One major reason for choosing the DNX 9980 over other Kenwood units was the dedicated center channel for 5.1 surround sound - i.e. 7 pre outs. I like watching TV on long trips. Please overlook safety/legality issues. I felt that the center channel speaker would enhance listening to movie dialog. The DNX 9980 provides complete control of the center speaker including auto turn off in the absence of 5.1 programming.
The new DNX 9990 was reportedly going to offer improved processing speed, true VGA screen resolution, built in HD radio, plus several other improvements. Then comes the bad news. Kenwood eliminated the center channel in the DNX 9990!
SOB. So now I must reconsider. Center speaker vs. improvements. How improved is the listening experience from 5.1 sources. I am aware of the muddled sound that comes from the Bose center speaker, i.e. mixed right and left channels. That is not what I am referring to. Can anyone share with me their experience with amping the center channel on a Kenwood DNX 9980? It is my understanding that you can turn the center speaker on and off in the zone control. Is sound improved with the speaker on or off? Bottom line: Does the center channel improve watching movies enough (especially in a convertable) to make it worth pursuing.
the 9980 has hd radio as well.... When I mine installed I noticed it had all kinds of control for sound and speakers including stage, surround sound and even time alignment. You can even select what type and size of speakers you are running. I am almost 100% positve you could turn the surround on and off in the unit but mine was in a c5 so I never used that function.
I really think the improved speed and gui of the 9990 as well as the other improvements will supersede the center channel. One thing to think of, it will be a few months before you can get the 9990, and once it does come out, the 9980 should be cheaper. So go check out the 9990 when you can, then if its not your cup of tea get the 9980.
you will also have to replace the entire factory amplifiers and speakers.
the best feature you can use with either head unit is the time alignment. once you get that dialed in the sound is awesome!
of what its worth, the only time your going to get true 5.1 is when you watch DVD movies, any other time its just pro logic surround from any 2 channel source and the center speaker ends up becoming pretty much useless anyway.
i have played with the new 9990 and i must say it is faster, better GUI and easier to use.
when they are available ill be able to get my hands on one for cost. if your interested let me know.
Former Vendor
something you need to consider, to get the center speaker working you'll need an amp as the output of the HU is preamp only!
Former Vendor
I would assume yes
untill I can actually see them I cant honestly answer
I will have the 6990 at the end of the week so will check the harness on that one and compare to the 6980
Thanks for the replys. I have decided to go with the new DNX 9990. I have given up on trying to save the 5.1 center channel. I will post pictures of how to install a 3 component speaker system (6.5-4.0-1.25) in the doors of a C6. I am exceeding pleased with how clean and unobstucted the installation is turning out.
