HU adjustments
HU adjustments
This is my system (Pioneer 4300 DVD HU, JL stealthbox sub, Focal 165KR fronts, Focal 130KRC rears, Kenwood XR5S amp). On the HU does it make sense to set the High Pass Filter to 80 Hz and the Sub low pass filter also to 80Hz. Is it best to keep these the same? I also have the option to set these higher or lower. Any suggestions?
1 Post
How do you like the 165KRs? Those are on my want list but the price is a bit scary.
I really like the 165KRs. They can put out an amazing amount of sound with a lot of clarity. I can play light jazz or classical pieces and you can hear everything. Something like Rhapsody in Blue when you have the initial clarinet note is pure and sweet. Then if you change to some rock or even hip hop (kids) you can get the pounding bass, crisp lows and great vocals.
I have had to turn down the high end on the EQ as these speakers are a bit "bright."
The price is high but this is my daily driver and I spend a lot of time in her. c5bear provided me with all my equipment and support. Highly recommended.
