Sponsored by: DashLynx
Max Door Speaker Depth
Old 03-15-2012, 11:14 PM
Mike Green9
Mike Green9's Avatar
Default Max Door Speaker Depth
Hi.
C6.
I will be swapping out the 10" Bose speakers in my C6. How much clearance is there re speaker mounting depth? I've seen specs go from 2.25 to 2 15/16".
Thanks,
M....
Old 03-15-2012, 11:32 PM
markcz
markcz's Avatar
My last set had 2.75" deep speakers and I know I had at least 1/2" more room behind that, probably closer to 1".
Any 'normal' 6.5" speaker will fit just fine.
Old 03-16-2012, 09:10 AM
Mike Green9
Hi.
I have been looking at the Massive RK6 and was concerned that they are a bit deep:
http://www.sonicelectronix.com/item_...udio-RK-6.html
Have you heard anything about these ?
Thanks,
M...
Old 03-17-2012, 03:15 PM
CraigE
Support Corvetteforum!
CraigE's Avatar
C6 Lower Door Speaker Depth
2007 C6 Doors
From face of OEM fiberglass baffle;
2-7/8" to sled
3-1/8" to rail.
3-3/4" to glass.
Caution that is ZERO clearance !
ClashBandicoot (11-03-2016)
Old 04-03-2012, 11:42 PM
SDB_FTW
SDB_FTW's Avatar
Don't forget to include the thickness of the speaker adapter you'll be using as an addition to the mounting depth. I cut my adapters out of 3/4" mdf, so mounting depth was increased by that amount and was virtually a non-issue for me, not that the door is particularly shallow to begin with.
Old 04-04-2012, 08:55 AM
Mike Green9
Thanks guys - good info
M....
Old 01-07-2017, 05:58 PM
ClashBandicoot
ClashBandicoot's Avatar
Guys i installed 8" door speakers in my vette no problem!! Stay tuned
Old 07-28-2019, 02:35 PM
Njttz
Njttz's Avatar
I have two more questions. First, what size is the OEM corner dash speakers in a ‘13? Second, has anyone had trouble with lower door speakers being too thick and the top mount height too high, resulting in door panel interference? I was looking at a set of 6.5 components on Crutchfield and they said there was a topside interference with the door panel. I understand that thickness of an adapter plate directly plays into this.
Old 07-28-2019, 02:52 PM
TorchRedFred
TorchRedFred's Avatar
Received 1,636 Likes on 1,121 Posts
I believe all the dash speakers are 3.5". 6.5" components will fit with no issue. The picture is deceiving but the door panel does not touch the speaker. I used Metra speaker adapter plates to mount mine. With the dash speakers, I recommend just disconnecting the stock ones and leave it at that. Here is a picture of my speakers with Metra adapter plates for the tweeter and woofer.
Old 07-28-2019, 03:40 PM
Njttz
Njttz's Avatar
What size tweeter is that? It looks bigger than the standard one.
Update: I got off my lazy butt, popped the dash tweeter, and as was written earlier it was extremely easy with an interior/trim pry tool. The factory uses a standard size tweeter probably around 3/4 inch that is directly attached to the grill. The max opening is around 3” but the cutout is only for the grill so it extremely shallow. The actual opening through the dash is around 1.5 in. This would require installing anything but a tweeter in these corner locations to be cutting up the dash and I’m not doing that. So.... I’m looking over three way 6.5/6.75 systems and putting the tweeters in these corner dash locations or going with a two way with everything in the doors.
Old 07-28-2019, 05:57 PM
TorchRedFred
I Have a set of Focal KRX2 components in the door. And a set of Morel Hybrid Integra 5.25" coaxial in the rear along with a JL subwoofer. Nothing in the dash except the disconnected factory speakers.
Old 07-30-2019, 10:28 AM
PCMusicGuy
PCMusicGuy's Avatar
2007 C6 Doors
2-7/8" to sled
3-1/8" to rail.
3-3/4" to glass.
When you say front face of OEM fiberglass baffle, do you mean the front face of the door itself once the speaker is removed? Also, when you say sled, are you talking the sled for the glass?
The only reason I ask is that I measured it this past weekend and from the bolt on the sled to the front face, I only have 2.5".
To Max Door Speaker Depth
Quick Reply: Max Door Speaker Depth
