Sponsored by: DashLynx
pioneer avic z140bh question, problem I think
Old 05-11-2012, 09:53 PM
Cavi
Cavi's Avatar
Default pioneer avic z140bh question, problem I think
got my 140 installed today, and initially it was great, sounded fantastic, but after awhile, it started acting up, the ATT sign started comming on on the top right corner, and basically I could not control the volume, the unit was trying to attenuate itself, it would flicker then after a bit it would just stay attenuated.
Any ideas? I did try and reset factory settings just incase I did something wrong.
Help please!!!
Old 05-11-2012, 11:12 PM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
the mute wire is bare behind the radio and resting on something metal, pull radio, find mute wire, and tape the end of it up
Old 05-12-2012, 12:44 AM
Cavi
Cavi's Avatar
I did not install it, will I hurt anything if I leave it this way until Monday when the guy who installed it can do it?
Old 05-12-2012, 04:28 PM
markcz
markcz's Avatar
It should be fine.
Old 05-12-2012, 06:20 PM
Cavi
Cavi's Avatar
I am leaning more twords a defective unit, when the car is cold it does fine, after the unit is on for an hour or so it starts then reaches a point where the ATT is on permanently. Also today it was parked in the sun all morning and as soon as I got in it was ATT right away....Bummer
Old 04-05-2013, 03:49 PM
benbrownfield
benbrownfield's Avatar
I just installed the same unit in my 05. I used the axxess wire harness for the install. Mine will play for 30 min-45minwwithout any issues, the ATT will display and lower the volume. That stays on until the next day. Any thoughts or ideas?
Old 04-05-2013, 07:37 PM
markcz
markcz's Avatar
Sounds like both may have overheating issues, which assumes the unit will put itself into ATT if it gets too hot
To pioneer avic z140bh question, problem I think
Quick Reply: pioneer avic z140bh question, problem I think
