Sponsored by: DashLynx
radio reception
Old 08-04-2012, 04:19 PM
DIABL0
DIABL0's Avatar
Default radio reception
How come when you replace a factory radio with an expensive aftermarket the radio reception goes to hell?
Old 08-04-2012, 06:08 PM
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Use the search this thread button over on the right. There are plenty of write ups to keep you busy and get to the root of your question.
Old 08-04-2012, 09:40 PM
chevyc6z51
chevyc6z51's Avatar
Ya I want to know to!
Old 08-05-2012, 01:04 AM
onspeed
onspeed's Avatar
I've already searched. And I still have the same question as the OP. And it's not related to antenna amplifier or etc since I have a Z06.
edit - to clarify, I want to know the reason why the reception on an aftermarket unit is worse than stock, not have someone tell me that I need to buy an antenna booster.
Old 08-05-2012, 03:39 PM
bowtiebubba
bowtiebubba's Avatar
I would like to know also.
Old 08-05-2012, 03:42 PM
DIABL0
DIABL0's Avatar
Thats what im talking about
Old 08-05-2012, 04:02 PM
markcz
markcz's Avatar
Plastic cars make for bad antennas
Old 08-05-2012, 04:05 PM
RLSebring
Supporting Vendor
RLSebring's Avatar
St. Jude Donor '17
I misunderstood the question. I thought they wanted to know how to improve the otherwise poor reception.
Old 08-05-2012, 04:11 PM
DIABL0
DIABL0's Avatar
Ya but stock radio is great why not aftermarket
Old 08-05-2012, 08:43 PM
RLSebring
Supporting Vendor
RLSebring's Avatar
St. Jude Donor '17
If the aftermarket HU isn't hooked up the same way the stock unit is the reception will suck. Mine did until I hooked it up correctly. The 12v booster did wonders too for the High Def channels.
Old 08-06-2012, 01:48 PM
onspeed
onspeed's Avatar
What about for those of us with C5Z or FRC, where there is no antenna booster?
Old 08-06-2012, 05:28 PM
markcz
markcz's Avatar
GM can spec out the radio as "gets great reception with a crappy antenna" and that's what they get. Aftermarkets are made to get good reception in the average metal car.
Try one of these
Old 08-07-2012, 12:24 AM
onspeed
onspeed's Avatar
What's the compromise when tuning the radio to get better reception as GM supposedly does? I don't hear a difference in sound quality... wouldn't it make sense for all radios to be tuned as such?
Old 08-07-2012, 12:05 PM
jcgunn
jcgunn's Avatar
I put a Pioneer 8200BT in my 03 Vert (OEM power antenna) it has the BEST reception (AM and FM) of any car I have ever owned...
Old 08-07-2012, 04:35 PM
markcz
markcz's Avatar
If you have an antenna that gets GREAT reception, then put it into a radio that amplifies it, there's a good chance you'll get a fair amount of interference or echos on stronger channels. GM is able to match the radio and antenna so they work well together, swapping out gear for aftermarket equipment messes the system balance up. Some radios do good, most not so well.
Old 08-27-2012, 11:12 PM
onspeed
onspeed's Avatar
Try one of these
Did not work. Made it worse actually.
Old 08-31-2012, 10:23 AM
s4k4zulu
s4k4zulu's Avatar
+1. same here
To radio reception
Quick Reply: radio reception
