2013 1LT Base Stereo Upgrade Recommendations
Folks -
Just picked up a 1LT Coupe (coming out of a 08 3LT w/ Nav).
Anyway - I figured i'd upgrade the system, and have done installs "back in the day" so was hoping for some recommendations.
Ideally, i'd probably like to keep the head unit and upgrade amps/speakers/sub.
However - if the head unit swap makes sense/easier, then i'm good w/ that. Nav is not a must, but would be neat.
Anyway - my budget is tight. I am thinking 1K max
Any recommendations/advice?
Thanks,
Aceman
Thanks,
Aceman
can deff do a speaker and amp upgrade for 1k. not necessary to replace the headunit if you dont want to
anything special you want/need or dont want? subwoofer?
would not be averse to a sub but not mandatory. I really want something that when i crank the volume i don't hear distortion/vibration/etc...
~$400 - 10" fiberglass corner sub box
~$300 - 4 channel bridgeable amp
~$200 - 6.5" front components
~$100 - misc wires & DIY Add-GM24
$1000 for a very good sounding amp/sub/speaker setup with oem radio
I'm sure Dennis can even send it all in one box if you gave him a call
Former Vendor
608 568 3011
I have MANY MANY options for you
Example
Driver side sub box with Kicker CVT 10
Kenwood x700-5 amp
Focal Performance PC165 components
aoemgm24 harness
amp kit, wiring, speaker baffles
shipping
1099.99
Former Vendor
