Sponsored by: DashLynx
05 C6 Vert where is the antenna amplifier located
Old 01-21-2013, 03:31 PM
Rayzzz
Rayzzz's Avatar
Default 05 C6 Vert where is the antenna amplifier located
On my 05 C6 Vert where is the antenna amplifier located? I'm trying to see if I can check from that location to see if the antenna amplifier is getting power and what wire do I check. I think it's in the rear pass trunk Cobbie hole. Hair puller so far .
Also I'm thinking of replacing the antenna system with new amplified antenna system. Any suggestion on a brand that would get the FM radio coming in good from my new Pioneer avic head unit install. When I install the PAC interface that should have sent power to the antenna amplifier.
THANKS RAYZZZ MY CORVETTE LIKES MY MONEY
Old 01-21-2013, 05:44 PM
markcz
markcz's Avatar
C6 prints HERE
All antenna pieces and parts are on the rear trunk wall under the vertical molded carpet piece.
Putting power to the white wire on B3 of the main plug triggers on both the oem amp and oem antenna.
If already powered I'd try one of THESE first, it helped a good bit in my '07. If that doesn't make you happy I'd go with something like THIS
Old 01-21-2013, 08:49 PM
Rayzzz
Rayzzz's Avatar
Originally Posted by markcz
C6 prints HERE
Purchase this one today. Thanks for the info. Hope this works out I'll let you know.
Metra 44-UA200
To 05 C6 Vert where is the antenna amplifier located
Quick Reply: 05 C6 Vert where is the antenna amplifier located
