GMOS-04: Audio only when chimes are ringing
No problem.... This should take care of the problem.... Adjust it with volume up and door open and key in acc position so chime is going as well
Everything working now except for the microphone for the handsfree. Was I supposed to install the separate mic that came with the DNX? I thought it would use the built-in mic.
You need to use the mic that came with the new HU
In my experience the tape that comes on aftermarket mics is pretty cheap, try using a clip under the trim or a small piece of the 3M double sticky tape.
All is well now ... I think
Thanks Dennis, 1FUNC5, and markcz.
By the way, I'm quite good now at removing and reinstalling a C6 console.
Larry
Larry
Just want to thank you guys for posting this! Without knowing any better I connected the blue/pink wire from the gmos (along with the blue/white one) and that was causing the radio to cut audio off completely- except for when the chimes went on.
Solved!
Thanks again. I created an account just to say this.
Solved!
