Sponsored by: DashLynx
C6 Pak adapter question
Old 06-01-2013, 05:25 PM
vetten76
vetten76's Avatar
Default C6 Pak adapter question
If I don't care about onstar, warning bells, or the radio staying on after I kill the engine, why do I need a pak adapter? Why can't I just tap into the stock wires for what I need?
Old 06-01-2013, 07:16 PM
markcz
markcz's Avatar
If you're replacing EVERYTHING in the car and don't care about chimes or onstar, then all you need is switched power from the footwell.
You'll still need to power up antenna module by splicing HU amp remote into wire B3 of plug C1.
C2R-GM24 isn't expensive to keep RAP and chimes. Just the CM1 (even cheaper) can be wired in for chimes but no RAP.
Old 06-01-2013, 07:20 PM
vetten76
vetten76's Avatar
Outstanding answer Mark. I was hoping you'd answer my question. Is this what you do fora living?
Old 06-01-2013, 07:30 PM
vetten76
vetten76's Avatar
Outstanding answer Mark. I was hoping you'd answer my question. Is this what you do for a living?
I've no problem using the c2r-gm24. I really dislike the RAP feature. Can I simply not connect a wire to disable that?
Old 06-01-2013, 09:38 PM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
Just get switched power at the fuse box then
Old 06-01-2013, 10:02 PM
markcz
markcz's Avatar
My work is multi-craft industrial maintenance, this car stuff is easy in comparison.
yep
To C6 Pak adapter question
Quick Reply: C6 Pak adapter question
