FS: 200 watt Marine/Car Amp Ssl H202.200
I bought a few of these for a project and 2 did the job instead of 4.
These are great little amps and can't beat the price.
You can use them in a boat, car or motorcycle.
You can bridge it and it will power a small sub.
Selling for what I paid for them.
$50 shipped to the U.S.
http://caramplifierrecommendation.bl...chan-200w.html
Marine grade amp
2 channel
100w x 2 max power @ 2ohm
50w x 2 rms power @ 4ohm
low pass crossover 120hz (fixed)
fuse rating: 1 x 7.5 amps
dim: 1.75"h x 9"w x 5"d
variable input gain control
power & protection leds
line & speaker level inputs
chrome plated rca connectors & screw terminals
freq resp: 12 hz-22 khz (+/-3 db)
signal-to-noise ratio: 90 db
thd at rms output: 0.01%
damping factor: 125+
P.M. Me if interested.
Marine grade amp
2 channel
Forgot to add, also have these.
LS65 6.5-Inch 2-Way Speaker with 350-Watt
1pr
$30 shipped.
Poly-coated paper cone
Santoprene surround
High temperature aluminum voice coil
Mylar dome tweeter
Frequency response: 65Hz-20kHz
Poly-coated paper cone Santoprene surround High temperature aluminum voice coil Mylar dome tweeter
Peak power handling: 350WMagnet structure: 35 Oz. Efficiency: 90dB (1 Watt/1 Meter)
Impedance : 4 ohm Frequency Response: 65Hz-20kHzMounting Depth: 2-5/16"
1pr
$30 shipped.
Santoprene surround
Mylar dome tweeter
